Knochenjonny Posted March 29, 2010 Share Posted March 29, 2010 Hello i have a question about drawing a line, but not a simple i mean a special one. See, i want to draw a line that fade out the colour ? I think to draw more a curve like that one the picture (ive done that but dont know how xDDDD) I only want to draw a curve / line and the line colour have to ... fade out or goes into another colour with antialias if possible. Plase help me ^^ Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted March 29, 2010 Share Posted March 29, 2010 I'm not sure what it is you actually want. I attached a pic of what I think you might be trying to say. (the last one is just a cool effect I made while trying to do what you said ) If none of those is it, could you please be more specific about what you want? thanks! Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Knochenjonny Posted March 30, 2010 Author Share Posted March 30, 2010 Hell ya thats it ^^can you tell me the trick ? please I want exactly this, can you adjust the radios from the colour effect, i mean thhat the blue colour goes into black, gradient i think is the word im searching for its hard to explain, im from germany and dont know the exactly discriptions xDDDDD but loock at my picture above a blue curve and from the buttom of the picture the blue colour goes over to black but the curve is to identify ? Quote Link to comment Share on other sites More sharing options...
someone93 Posted April 5, 2010 Share Posted April 5, 2010 (edited) Hell ya thats it ^^can you tell me the trick ? please I want exactly this, can you adjust the radios from the colour effect, i mean thhat the blue colour goes into black, gradient i think is the word im searching for its hard to explain, im from germany and dont know the exactly discriptions xDDDDD but loock at my picture above a blue curve and from the buttom of the picture the blue colour goes over to black but the curve is to identify ? Try the different blurs. I think a combination of a subtle Radial Blur and Gaussian Blur should work quite well. Edited April 5, 2010 by someone93 Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted April 5, 2010 Share Posted April 5, 2010 Follow the tutorial in the attachment from 1-7. Should get you what you want Edit by Rick: Deleted 1MB attachment... why on earth would you post that here? Upload it to your own server and post a link. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
someone93 Posted April 5, 2010 Share Posted April 5, 2010 In addition to L3ron's second how to, you could also use a radial blur placed below the edge of the canvas if the line is at the bottom and vice versa. Quote Link to comment Share on other sites More sharing options...
someone93 Posted April 5, 2010 Share Posted April 5, 2010 (edited) In addition to L3ron's second how to, you could also use a radial blur placed below the edge of the canvas if the line is at the bottom and vice versa. Edit: I came up with this using the above technique: Edited April 5, 2010 by someone93 Quote Link to comment Share on other sites More sharing options...
Knochenjonny Posted April 6, 2010 Author Share Posted April 6, 2010 That is great, thank you all for the tips. I tray it later and let you know if it works Quote Link to comment Share on other sites More sharing options...
someone93 Posted April 12, 2010 Share Posted April 12, 2010 You did this with my second tut? Nice to see taht it really works :D The things I did was very similar to the ones in your tut. Quote Link to comment Share on other sites More sharing options...
