Help making a certain picture
Breakdown:
the background looks like a wall stock so thats watcha gonna use first i think.. (or create a texture grungy wall texture) which you can finde under tutorials > texture...
then some glowing lines with low opacity or overlay blendmode... you can probably find a tutorial on that... or just draw some and then play with the blendmodes... (or use some brushes which i think is used here...)
and then the text...i think its a font with a Logo and some gradients :|...
