kitty_love Posted March 15, 2010 Share Posted March 15, 2010 Ok, so I downloaded Smudge and Splatter AGAIN, because before I couldn't find either one in PDN. (Augh) So when I try to use it it doesn't work. As in, a popup says: "This plugin has encountered an error, and must be closed. Because of the unpredictable nature of these types of errors, it is strongly recommended that you restart Paint.NET before proceeding. Otherwise, there could be further stability problems or data corruption" I have v. 3.5.4. (Assuming that's the latest version...) The plugins are in the right place. What am I doing wrong? I looked under "View Plugin Load Errors..." Hidden Content: 1 of 15-------------- File: C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll Effect Name: PaintDotNet.SystemLayer.IFileDialogUICallbacks Full error message: System.TypeLoadException: Could not load type 'PaintDotNet.SystemLayer.IFileDialogUICallbacks' from assembly 'PaintDotNet.SystemLayer, Version=3.54.3708.31974, Culture=neutral, PublicKeyToken=null'. 2 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\pyrochild.effects.common.dll Effect Name: PaintDotNet.UserControl2 Full error message: System.TypeLoadException: Could not load type 'PaintDotNet.UserControl2' from assembly 'PaintDotNet.Core, Version=3.54.3708.31976, Culture=neutral, PublicKeyToken=null'. 3 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\pyrochild.effects.common.dll Effect Name: PaintDotNet.SurfaceBoxGraphicsRenderer Full error message: System.TypeLoadException: Could not load type 'PaintDotNet.SurfaceBoxGraphicsRenderer' from assembly 'PaintDotNet.Core, Version=3.54.3708.31976, Culture=neutral, PublicKeyToken=null'. 4 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Smudge.dll Effect Name: (Not Supplied) Full error message: System.IO.FileNotFoundException: Could not load file or assembly 'pyrochild.effects.REQUIRED, Version=3.6.3627.29844, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'pyrochild.effects.REQUIRED, Version=3.6.3627.29844, Culture=neutral, PublicKeyToken=null' WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. 5 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Splatter.dll Effect Name: (Not Supplied) Full error message: System.IO.FileNotFoundException: Could not load file or assembly 'pyrochild.effects.REQUIRED, Version=3.6.3627.29844, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'pyrochild.effects.REQUIRED, Version=3.6.3627.29844, Culture=neutral, PublicKeyToken=null' WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. 6 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Color Match.dll Effect Name: pyrochild.effects.colormatch.ColorMatch Full error message: This plugin is incompatible with this version of Paint.NET. 7 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Curves+.dll Effect Name: pyrochild.effects.curvesplus.CurvesPlus Full error message: This plugin is incompatible with this version of Paint.NET. 8 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\CustomBrushes.dll Effect Name: CustomBrushes.EffectPlugin Full error message: This plugin is known to cause stability problems. 9 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll Name: EdHarvey.Edfects.Effects.DentsWarpPlusEffect Version: 3.36.3160.38013 Author: Ed Harvey Copyright: Copyright © 2006-2008, Ed Harvey Website: viewtopic.php?f=16 Full error message: This plugin is now built-in to Paint.NET. 10 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll Name: EdHarvey.Edfects.Effects.SurfaceBlurEffect Version: 3.36.3160.38013 Author: Ed Harvey Copyright: Copyright © 2006-2008, Ed Harvey Website: viewtopic.php?f=16 Full error message: This plugin is now built-in to Paint.NET. 11 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll Name: EdHarvey.Edfects.Effects.CrystalizeEffect Version: 3.36.3160.38013 Author: Ed Harvey Copyright: Copyright © 2006-2008, Ed Harvey Website: viewtopic.php?f=16 Full error message: This plugin is now built-in to Paint.NET. 12 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll Effect Name: EdHarvey.Edfects.Effects.LensBlurEffect Full error message: This plugin is now built-in to Paint.NET. 13 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll Effect Name: pyrochild.effects.gradientmapping.GradientMapping Full error message: This plugin is incompatible with this version of Paint.NET. 14 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\Random Effect.dll Effect Name: pyrochild.effects.randomeffect.RandomEffect Full error message: This plugin is incompatible with this version of Paint.NET. 15 of 15 -------------- File: C:\Program Files\Paint.NET\Effects\ScriptLab.dll Effect Name: pyrochild.effects.scriptlab.ScriptLab Full error message: This plugin is incompatible with this version of Paint.NET. Oh, and, if this is already posted.... Or in the wrong place..... -Hands you a baseball bat- Hit me with it. (Gah, and the 2 plugins are some of my favorites too >.< ) Amateur for life, eh? Link to comment Share on other sites More sharing options...
BoltBait Posted March 16, 2010 Share Posted March 16, 2010 Read this: viewtopic.php?f=10&t=23939 Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
