lordtinuviel Posted September 16, 2006 Share Posted September 16, 2006 I'm trying to install Paint.net v2.72 but i get the following error: ************** Exception Text ************** System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Daeron Tin�viel\AppData\Local\Temp\PdnSetup\PaintDotNet.msi'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite) at System.IO.FileInfo.CopyTo(String destFileName, Boolean overwrite) at PaintDotNet.Setup.InstallingPage.DoInstallation() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.112 (rtmLHS.050727-1100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- SetupFrontEnd Assembly Version: 2.72.2432.31568 Win32 Version: n/a CodeBase: file:///C:/Users/Daeron%20Tin%FAviel/AppData/Local/Temp/PdnSetup/SetupFrontEnd.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.112 (rtmLHS.050727-1100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.112 (rtmLHS.050727-1100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.112 (rtmLHS.050727-1100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- PaintDotNet.Resources Assembly Version: 2.72.2432.31552 Win32 Version: n/a CodeBase: file:///C:/Users/Daeron%20Tin%FAviel/AppData/Local/Temp/PdnSetup/PaintDotNet.Resources.DLL ---------------------------------------- PaintDotNet.SystemLayer Assembly Version: 2.72.2432.31553 Win32 Version: n/a CodeBase: file:///C:/Users/Daeron%20Tin%FAviel/AppData/Local/Temp/PdnSetup/PaintDotNet.SystemLayer.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.112 (rtmLHS.050727-1100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- thkz for any help u can provide Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted September 16, 2006 Share Posted September 16, 2006 Does your last name contain an accent? This seems a part of the problem... I believe Tinúviel Quote ~~ Link to comment Share on other sites More sharing options...
lordtinuviel Posted September 16, 2006 Author Share Posted September 16, 2006 yes why? and if so what do i have to do to fix it? thkz ----------------------------------------------------------------------------------------- edit: thinkin about your comment i decide to login with my wife account and try it to install it and voila it did!!! thankz!!!! Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted September 16, 2006 Share Posted September 16, 2006 Ok. Rick, can you say there is a bug for the installer's handling of special characters in file paths? Quote ~~ Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 16, 2006 Share Posted September 16, 2006 That would seem to be the case. Looks like the .NET Framework just doesn't like it. Actually, judging by the call stack, it looks like Windows itself is frowning on it. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 16, 2006 Share Posted September 16, 2006 This should be in Bugs & Troubleshooting. Please be sure to post in the right forum. Moved Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Illnab1024 Posted September 16, 2006 Share Posted September 16, 2006 @Tinúviel: This might be something you would want to post over at MSDN net Vista bugs, see what they say. Quote ~~ Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 16, 2006 Share Posted September 16, 2006 Does this happen on XP? If not then I can simply file a bug on Vista and track it myself. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Illnab1024 Posted September 16, 2006 Share Posted September 16, 2006 I'll see... EDIT: Nope. It must be isolated to Vista. Quote ~~ Link to comment Share on other sites More sharing options...
