Servant_Of_Thor Posted February 26, 2010 Share Posted February 26, 2010 I have an image pack i'm making into brushes, but a few of them come out skewed, or stretched. Any way I can stop that from happening? :? Quote "I'm attracted to you like the Earth is attracted to the Sun - with a large force inversely proportional to the distance squared." My Gallery Link to comment Share on other sites More sharing options...
Sarkut Posted February 26, 2010 Share Posted February 26, 2010 Be sure that the image used as a brush is on a square canvas. The brush tool will treat it as square and squish it otherwise. Quote Link to comment Share on other sites More sharing options...
Servant_Of_Thor Posted February 26, 2010 Author Share Posted February 26, 2010 So, if i use the lasso tool and select around the picture to be made into a brush, that would cause it to stretch? If thats it sweet, easy fix, thanks. Quote "I'm attracted to you like the Earth is attracted to the Sun - with a large force inversely proportional to the distance squared." My Gallery Link to comment Share on other sites More sharing options...
Sarkut Posted February 26, 2010 Share Posted February 26, 2010 Yeah, actually regardless of how you make the image, the canvas aspect ratio is what's important. So, if I open PDN with a default 800 X 600 canvas I need to crop to 600 X 600 before saving or the brush will look squashed-in sideways in use. Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted February 26, 2010 Share Posted February 26, 2010 Is this just in the brush list or actually on the canvas? Quote Link to comment Share on other sites More sharing options...
Sarkut Posted February 26, 2010 Share Posted February 26, 2010 Actually, now that I check, it applies only to my Paint.Net v.3.36 setup. In the current version, it looks squashed in the brush list, but applies as a brush without distortion. Quote Link to comment Share on other sites More sharing options...
Servant_Of_Thor Posted February 26, 2010 Author Share Posted February 26, 2010 Sweet thats real easy. Thanks! Quote "I'm attracted to you like the Earth is attracted to the Sun - with a large force inversely proportional to the distance squared." My Gallery Link to comment Share on other sites More sharing options...
markcasias Posted February 26, 2010 Share Posted February 26, 2010 that's cool, thanks for the ..... Quote http://www.kinder-digitalkamera.com Link to comment Share on other sites More sharing options...
