Leano Posted February 25, 2010 Share Posted February 25, 2010 Hi all I have only recently go Paint.NET, i would like to know how does one remove a section on a painting? Thank you Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 25, 2010 Share Posted February 25, 2010 Hi Leno, If you want to crop the sides, select the part you want to keep with the rectangle selection tool and then hit CTRL + Shift + X If you want to remove part of the image, check out this tutorial: Cutting out images. If you want to remove part of the image and fill in the hole that is left, you'll need the Clone Stamp tool or this plugin: Fill Gaps 1.0 Hope this helps. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
