Mike Ryan 15 Posted March 3, 2010 Report Share Posted March 3, 2010 In the new version if all of the settings were blank then it would run a black and white copy of the layer as mask. It doesn't do that anymore, instead not running any mask. Quote Link to post Share on other sites
aguba 0 Posted March 3, 2010 Author Report Share Posted March 3, 2010 Oh wow, that's a shame. You're plugin does provide a suitable work-around however Quote aguba.deviantart Link to post Share on other sites
Sarkut 7 Posted March 3, 2010 Report Share Posted March 3, 2010 You're plugin does provide a suitable work-around however aguba, You might want to clarify that statement. It sounds like you are telling people that they can do your tutorial successfully using Mike's plugin as an alternative to the Alpha Mask Import plugin. Quote Link to post Share on other sites
Mike Ryan 15 Posted March 3, 2010 Report Share Posted March 3, 2010 You're plugin does provide a suitable work-around however aguba, You might want to clarify that statement. It sounds like you are telling people that they can do yoututorial successfully using Mike's plugin as an alternative to the Alpha Mask Import plugin. Out of curiosity, what do you mean? Quote Link to post Share on other sites
Sarkut 7 Posted March 3, 2010 Report Share Posted March 3, 2010 The tutorial includes loading a mask using Browse, for example. I didn't see a browse function on the UI of Isolate White / Black. If it will do everything the tutorial requires that's great. Can it use the values from one layer as a mask for another layer? Quote Link to post Share on other sites
aguba 0 Posted March 4, 2010 Author Report Share Posted March 4, 2010 Sorry, my bad. I meant that it creates a workaround for that specific part of the tutorial, where you don't have to load any alpha masks. The Alpha Mask Import plugin is still required. Quote aguba.deviantart Link to post Share on other sites
pyrochild 362 Posted April 6, 2010 Report Share Posted April 6, 2010 Aguba, I've written a new plugin called Trail that should make step 3 of this tutorial much faster. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
Ben Arie 0 Posted April 10, 2010 Report Share Posted April 10, 2010 (edited) Hello, this is my result (attached). It's a bit lighter than yours. I didn't figure out how to apply the gradient to the white lines, so I instead used gaussian blur and applied a glow. At the end, instead of turning light to 0 I turned it up a bit. I didn't use Vignette. Edit: This is my first try at this so it's not very original but I need to learn for now. I will be more original in my creations. Edited April 10, 2010 by Ben Arie Quote Link to post Share on other sites
Helena 0 Posted April 20, 2010 Report Share Posted April 20, 2010 (edited) Wow, you're right when you say that this tutorial requires a lot of time and patience... it took me hours, but I've learnt a lot of useful things, thank you for share your techniques. These are my attempts: Edited April 20, 2010 by Helena Quote Link to post Share on other sites
BulsAye 0 Posted April 23, 2010 Report Share Posted April 23, 2010 I had trouble in a certain section of the tutorial, but besides that thiss was a really good tutorial. I'm new to PdN, but i'm learning pretty fast. Please tell me what you think. ( Any critiques ) would be nice. . Quote Link to post Share on other sites
talionYzero 0 Posted April 24, 2010 Report Share Posted April 24, 2010 Here's my go Not the best, but I tried; maybe someday I'll try it again with more luck. Good tutorial though. Quote "I thought that you said we were all quite mad?""Why yes, my very lovely dear, but not quite as mad as the Hatter." Link to post Share on other sites
Pixey 4,809 Posted April 30, 2010 Report Share Posted April 30, 2010 Wow! What an amazing tutorial - for which many thanks. I will not admit to how long I took to do this ..... but it was many,many hours. I learned a lot but, like Ben Arie before me, I could not select and put a gradient to the white lines either. Bother! Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon.  Link to post Share on other sites
Sarkut 7 Posted May 1, 2010 Report Share Posted May 1, 2010 Pixey, To put a gradient to the white lines, you want to use a transparent radial gradient. Quote Link to post Share on other sites
Ben Arie 0 Posted May 2, 2010 Report Share Posted May 2, 2010 oooooooooooooooooohhhh..... right. Quote Link to post Share on other sites
Pixey 4,809 Posted May 2, 2010 Report Share Posted May 2, 2010 Pixey, To put a gradient to the white lines, you want to use a transparent radial gradient. Wow! Thanks for that tip and I managed to do it this time. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon.  Link to post Share on other sites
aguba 0 Posted June 2, 2010 Author Report Share Posted June 2, 2010 Been gone for awhile. Brilliant results guys, nice work. Aguba, I've written a new plugin called Trail that should make step 3 of this tutorial much faster. Excellent plugin pyro, definitely speeds things up. I may update the tutorial to include its use. Quote aguba.deviantart Link to post Share on other sites
Kaddl89 0 Posted June 13, 2010 Report Share Posted June 13, 2010 Hey I'm very new in Paint.net but I love this tutorial. You guys have all so great results... I've tried it so often ( really often ! with letters, circles... ) But I can't get an good looking result The funny thing is, on every try, I made different mistakes. Forgot layers, used false plugins... so I'm still trying to draw in 3 Dimensions and if I get anytime an result nearly goodlooking like yours, I will post it Quote Link to post Share on other sites
qoo2345 0 Posted June 21, 2010 Report Share Posted June 21, 2010 Hello , I have a problem at step 5 , the instruction says to brush the clone stamp over the shape , but when i click with my mouse nth happens . I just skipped this step cause i dun understand , i tried applying alpha mask , i click alpha mouse ,tick 'invert mask ' 'Mix alpha ' 'Paste To clipboard' , and what am I am suppose to browse what? The flattened image that i save earlier?( the step 4 ) rather confusing for me , im a newb in Photo softwares. Btw theres a typo here 'the Mix Alpha check-box must me ticked' the 'me' should be 'be'. Hope to receive help soon , dying to try making my own 3d Signatures Thanks in advance . Quote Link to post Share on other sites
dawv 0 Posted July 5, 2010 Report Share Posted July 5, 2010 Which alpha mask plugin? I found two completely different ones, but neither are called just Alpha Mask.. Quote Do not click! Link to post Share on other sites
Sarkut 7 Posted July 5, 2010 Report Share Posted July 5, 2010 (edited) Alpha Mask Import Plugin Edited July 5, 2010 by Sarkut Quote Link to post Share on other sites
dawv 0 Posted July 6, 2010 Report Share Posted July 6, 2010 (edited) Thanks. I kinda strayed from the tutorial a bit due to missing plugins but I like how it turned out... Edited July 6, 2010 by dawv Quote Do not click! Link to post Share on other sites
Kaddl89 0 Posted July 16, 2010 Report Share Posted July 16, 2010 Well from all My Trys on this Tutorial, I think this is actually the best one Thanks very much for this tut. I just love this oytcome Quote Link to post Share on other sites
Sean 0 Posted July 19, 2010 Report Share Posted July 19, 2010 (edited) It turned out good enough, but I wish it were better. I was actually trying to get it to look closer to your signature, aguba. Though, I used a different shading technique and went overboard on it. This was the second attempt, which is way better than my first was. Therefor, my next attempt shall be up to my standards. [: Excellent tutorial. Thanks! Here's my third try: I think it's better, but I couldn't quite get the shine right. Edited July 19, 2010 by Sean Quote Link to post Share on other sites
oliviathn 0 Posted August 5, 2010 Report Share Posted August 5, 2010 (edited) I worked with a lot of 3D before and found some of the differences of style with controls. For example, if you have two levels of circles then set in black color and other is white color, After that just set it in lighter than the second object which is darker. Now It looks so good and awesome pictures or image. Edited August 5, 2010 by oliviathn Quote iphone cases Link to post Share on other sites
Musiphonix 0 Posted August 11, 2010 Report Share Posted August 11, 2010 I did it! The image used as the "Shape" is my creation as well. Great tutorial! PS. The step that uses the feather plugin. There's a much easier way of doing it: 1. Use the magic wand tool to select the black area. 2. Use the "Outline Selection" plugin and fiddle about with the width. 3. Use alpha mask to remove the remaining black. I say this is easier, but that's just my personal preference. Quote |Image Gallery| |deviantART Page| |My Profile| Link to post Share on other sites
