Martel Posted February 12, 2010 Share Posted February 12, 2010 Hi all: I want to create a border to use for bulk border adding . Like hundreds of pics at the same time. I use Fast Stone Photo resizer (which by the way rocks ) uses a .ccf converter configuration file. But alas I have no such file. Any other suggestions are welcome. Thanks Link to comment Share on other sites More sharing options...
pyrochild Posted February 12, 2010 Share Posted February 12, 2010 Try looking into ImageMagick ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Martel Posted February 12, 2010 Author Share Posted February 12, 2010 Thanks pyrochild Link to comment Share on other sites More sharing options...
Martel Posted February 12, 2010 Author Share Posted February 12, 2010 Thanks pyrochild I found imagemajik lots of zip files ..scratching head Link to comment Share on other sites More sharing options...
pyrochild Posted February 12, 2010 Share Posted February 12, 2010 Try Googling for "batch add border" or variations thereof. ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Martel Posted February 12, 2010 Author Share Posted February 12, 2010 Thanks again, I will dig into it a little more to get it to do. Link to comment Share on other sites More sharing options...
pyrochild Posted February 12, 2010 Share Posted February 12, 2010 ImageMagick is powerful, but complex. I'm sure there are other programs out there that can batch process borders more easily; unfortunately, Paint.NET is not one of them, so I'm going to lock this thread. Good luck. ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
