chrisco97 Posted January 25, 2010 Share Posted January 25, 2010 I downloaded the "Custom Brushes Mini" plugin, and every time I select it, it says the following message: "This plugin has encountered an error, and must be closed. Because of the unpredictable nature of these types of errors, it is strongly recommended that you restart Paint.NET before proceeding. Otherwise, there could be further stability problems or data corruption." It says to restart Paint.NET, and I did. It still will not pull up. Please Help!! I really need this plugin for my sigs. Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted January 25, 2010 Share Posted January 25, 2010 Make sure you copied SBCommon.dll to the effects folder as well as CustomBrushesMini.dll. Quote Link to comment Share on other sites More sharing options...
chrisco97 Posted January 25, 2010 Author Share Posted January 25, 2010 Thanks! It worked!!!! Thank you so much! Quote Link to comment Share on other sites More sharing options...
