paulkenny Posted September 11, 2006 Share Posted September 11, 2006 Hi, I am having a problem installing the latest version of Paint .NET it is being installed onto a brand new laptop with windows XP, a valid .NET 2.0 installation with all updates. Attached is a screenshot of the error. Any suggestions or help would be much appreciated as I find this a very useful application. Cheers, Paul Quote Link to comment Share on other sites More sharing options...
Born2killx Posted September 11, 2006 Share Posted September 11, 2006 You should check the stickies before you post. http://paintdotnet.12.forumer.com/viewtopic.php?t=854 Quote I built my first computer at age 11! Link to comment Share on other sites More sharing options...
paulkenny Posted September 11, 2006 Author Share Posted September 11, 2006 I have checked the stickies ...none of the problems mentioned are similar to mine. Thanks for your reply, Paul Quote Link to comment Share on other sites More sharing options...
paulkenny Posted September 12, 2006 Author Share Posted September 12, 2006 Even though none of my symptoms matched those in the stickies I still followed their suggestions. Needless to say none of them worked for me. Does anyone have any suggestions? If not it is a pity as I really liked this app. Cheers, Paul Quote Link to comment Share on other sites More sharing options...
