mmierbeth Posted January 15, 2010 Share Posted January 15, 2010 I am trying to use the wand tool to seperate the background from a image I want out of the background. I can do this but the outline is choppy. Is there some way I could make the image outline smooth so the image will look good? Quote Link to comment Share on other sites More sharing options...
0(-.-)0 Posted January 15, 2010 Share Posted January 15, 2010 You can try using the feather plugin. Quote - Any thoughts? - Link to comment Share on other sites More sharing options...
theonlychad Posted January 15, 2010 Share Posted January 15, 2010 you can use the alpha mask import plugin by illnab Quote "Clearly it's a very serious and literal meaning. If you're not solving physics equations then get off my lawn!-Rick Brewster Paint.net Lead Developer" Link to comment Share on other sites More sharing options...
