pschroeter Posted January 10, 2010 Share Posted January 10, 2010 Is there a way for me to copy a picture in another program, then start PDN with the contents of the clipboard already Paste(d) in to New Image? The simple Paste command would be OK too. I think this would be kind of handy and it feels like something that could be done with a Windows shortcut with the right parameters. I don't want to use a macro program. I guess I need to stress PDN is not running before I copy the image from another source. It would be nicely convenient to have PDN start with the clipboard contents already pasted. Quote Link to comment Share on other sites More sharing options...
Zieon Eslador Posted January 10, 2010 Share Posted January 10, 2010 Ctrl + V Quote (Click top half for DeviantArt gallery) (Click bottom half for Paint.NET gallery) Link to comment Share on other sites More sharing options...
APShredder Posted January 10, 2010 Share Posted January 10, 2010 Actually, if you press Ctrl + Alt + V, a new image will be opened with the same dimensions as your copied image. Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Possum Roadkill Posted January 10, 2010 Share Posted January 10, 2010 Actually, if you press Ctrl + Alt + V, a new image will be opened with the same dimensions as your copied image. COOL ! Thanks ! Quote My Gallery SAC, WOTW and Photo Manip Competition Host To visit the Comps click HERE Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 11, 2010 Share Posted January 11, 2010 There's no way to get Paint.NET to auto-execute something like Ctrl+Alt+V. You'll simply have to do it manually. In other words, there's no /pasteIntoNewImage command-line parameter. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
