SKIN_YA Posted January 3, 2010 Share Posted January 3, 2010 over the last few days i have been working on a poker chip kind of thing its looking pretty good i have used shape 3d and make the chip stand up on its edge but its not looking a whole lot 3d any more i think it needs a shadow around the bottom so it looks like its standing up you may notice there is a large open space on the chip that is because there is some advertising text there that i did not think appropriate to leave there. also i have plans to put a new bit of text and animate it near the bottom when the shadow is done attached is the file that i am working on could i get the help in a mini tut style plz Quote Link to comment Share on other sites More sharing options...
Curmudgeon Posted January 3, 2010 Share Posted January 3, 2010 there's a tutorial here showing you how to make poker chips from scratch Quote Link to comment Share on other sites More sharing options...
SKIN_YA Posted January 3, 2010 Author Share Posted January 3, 2010 yes i know that and i used that but it dose not show how to do the shadow wow can't you c that i have already made the chip Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 3, 2010 Share Posted January 3, 2010 PLEASE STOP SHOUTING. You'll need to edit the title of your thread. Otherwise I will have to close this. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Curmudgeon Posted January 3, 2010 Share Posted January 3, 2010 yeah, I saw the chip...but was wondering why you just didn't adjust the lighting in shape3D...but then I read more closely and saw you wanted it standing up on edge... duplicate your chip set it to black and white adjust brightness/contrast both to 0 move that layer below your chip layer use layers>rotate/zoom, and pan/tilt it downwards and to the side adjust the opacity of the layer could also add a gaussian blur if you wanted...you didn't really specify how sharp the shadow was supposed to be should end up something like this: Quote Link to comment Share on other sites More sharing options...
SKIN_YA Posted January 4, 2010 Author Share Posted January 4, 2010 ok that looks nice but not quite what im after but maybe i can use that and turn it into what i want about the caps soz but my finger is big and i bump the caps lock a lot Quote Link to comment Share on other sites More sharing options...
