peachy.fudge Posted December 29, 2009 Share Posted December 29, 2009 Hey you guys. I have five images, and want to put them together to form a moving gif. Can you explain to me how I can do this using Paint.Net? If I can't do this using paint.net, are there any free websites that could help me do that? thanks ^^;; Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 30, 2009 Share Posted December 30, 2009 http://searchpaint.net/ + Gif Animator :wink: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
ayaaax Posted December 30, 2009 Share Posted December 30, 2009 Use this program: UnFREEz: http://rapidshare.com/files/327961905/UnFREEz.rar.html Quote Link to comment Share on other sites More sharing options...
PeterG Posted December 30, 2009 Share Posted December 30, 2009 There is a plugin available for use with Paint.NET, it is a "File Type" plugin. viewtopic.php?f=16&t=28407&start=180 Using layers, you can create and save, animated ".agif" files. To see the animation working, the "agif" file extension has to be manually changed to "gif", outside Paint.NET... you can edit the file name in explorer... To re do or edit the animation, you will need to re name back to "agif" and re open the file in Paint.NET I hope this helps... Peter Quote When nothing short of Divine Intervention can get the job done! Link to comment Share on other sites More sharing options...
