jimmybeem Posted December 28, 2009 Share Posted December 28, 2009 I read the topic for update installation problems, and tried a couple of fixes, but doesn't seem to pertain to my issue. I had a perfectly good working edition of paint.net until I upgraded to 3.5.1 as recommended when I fired up the program. Installation failed with error 1603, although it seemed get pretty far along into the process before the error occurred. I have nothing to uninstall, as there are no entries for paint.net in control panel. I have also tried deleting temporary files, the directories, etc. as well as update .net framework. I am running Windows 7 with .net framework 3.5.1. Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
JDMLee Posted December 29, 2009 Share Posted December 29, 2009 i am having the same problem getting error code 1603 when i guess upgraded which i dident even do i guess its a auto update it was working perfectly before land now this can i get some help plz thanks Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 29, 2009 Share Posted December 29, 2009 (edited) jimmybeem, JDMLee, I don't know whether you have already tried this. For a 1603 error, try downloading the current installation pack, and installing manually. (Rather than using auto-update.) http://www.dotpdn.com/downloads/pdn.html Choose the Custom install option, install to a non-default destination as detailed in this post: 1603 Error Edited April 21, 2010 by Sarkut Quote Link to comment Share on other sites More sharing options...
