recursor 10 Posted December 23, 2009 Share Posted December 23, 2009 (edited) I often use Paint .NET to make or modify sprite sheets, and one of the things I've always wanted to do was see the animation in action without having to leave Paint .NET. This plugin will allow you to do just that. It lets you view any sequence of animations within a sprite sheet by adjusting the offset, # of columns, and the total # of frames. You can also save all the frames off to individual .png files. Saving an animation as an animated GIF is also supported.New version 1.0.0.96 available (6/19/2018) Download it here. (The plugin is free but donations are appreciated to support further development if you find it useful) v1.0.0.96 Notes ========== - Add padding zeroes as needed when exporting individual frames v0.95 Notes ========== - Recompiled to use .NET 4.71 framework to be compatible with the latest Paint .NET release. I'm hoping this will help with any High DPI scaling issues. v0.94 Notes =========== - Animation frame is now drawn centered - Minor UI Changes - Changed the icon Edited June 19, 2018 by recursor update 5 Quote Link to post Share on other sites
recursor 10 Posted December 23, 2009 Author Share Posted December 23, 2009 Version 0.4: 1) Removed Status bar 2) Made Nearest neighbor the default for zooming. It looks much better this way. 3) The plugin is now located in the Animation category under the Effects menu Version 0.3 Bugs fixed: 1) Cell bitmap was not being cleared before drawing the next frame Quote Link to post Share on other sites
yellowman 277 Posted December 24, 2009 Share Posted December 24, 2009 I didn't get what exactly it does, so it just play the animation been working on in paint.net, but you can't use it to import or export files? And the layers are the frames? Looks interesting anyways, I ll give it a try, I like the UI EDIT: Never mind I just got it to use, looks cool, thank you very much for this plugin, I think I will never need it, but I am sure it is very important for some people to use with some applications. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
Dataflashsabot 0 Posted January 2, 2010 Share Posted January 2, 2010 Registered just to say thank you for this plugin, it's been invaluable. One suggestion, how about an option for nearest neighbor scaling instead of blurry linear scaling in the preview window? Quote Link to post Share on other sites
recursor 10 Posted January 2, 2010 Author Share Posted January 2, 2010 Glad it is useful to you. I have updated the plugin to use nearest neighbor for zooming as you suggested. It was something that had not occurred to me. I have also changed where it is located in the Effects drop down - it is now under Animation instead of Advanced Quote Link to post Share on other sites
oblachubs 0 Posted February 23, 2010 Share Posted February 23, 2010 Thanks. Does this assist with the tedious task of cutting sprite sheets or do I still have to do that? I usually open a new doc with a 32x32 pixel, select and copy the sprite from the master sheet, Ctrl Tab back to the blank doc and paste. then I may resize or magic wand it transparent. If there is an easier way I'm all ears. I've been trying it out and can't figure out how to use the plugin. I can't find documentation anywhere. Thanks! Quote Link to post Share on other sites
recursor 10 Posted May 30, 2010 Author Share Posted May 30, 2010 I just released version 0.5 Version Notes: =============== 1) Added ability to export each frame to a .png file (sprite sheet cutting) See first post in this topic for the download Quote Link to post Share on other sites
recursor 10 Posted June 5, 2010 Author Share Posted June 5, 2010 (edited) I have released Version 0.6 of the plugin. To see what has changed and to get the download link, check the first post in this topic. Edited June 5, 2010 by recursor Quote Link to post Share on other sites
recursor 10 Posted June 10, 2010 Author Share Posted June 10, 2010 (edited) I've released version 0.7 which now uses the current rectangular selection (if there is one) to fill in the frame width, height and x,y values. See the first post in this topic for the new file. Edited June 10, 2010 by recursor Quote Link to post Share on other sites
TxTARUNTxT 0 Posted July 9, 2010 Share Posted July 9, 2010 I don't think mine seems to work can you explain to me the steps on how to use it. A thousand thank yous Quote Link to post Share on other sites
recursor 10 Posted July 10, 2010 Author Share Posted July 10, 2010 I don't think mine seems to work can you explain to me the steps on how to use it. A thousand thank yous Certainly, Check out the tutorial video: Quote Link to post Share on other sites
MerlinJones 0 Posted August 12, 2010 Share Posted August 12, 2010 Recursor- Thanks for this, I was hoping to make something very similar. What are the chances you'd be willing to share the source so that I can make some updates for my own tastes? Giving you full credit for what you've already done, of course. Quote Link to post Share on other sites
recursor 10 Posted December 8, 2010 Author Share Posted December 8, 2010 (edited) Sprite Sheet Animation Helper Version 0.8 released V0.8 Notes: ============= 1) Fixed bug where if your selection rectangle was either as wide as or as tall as the original image, then the selection rectangle was ignored. 2) Added a frame counter 3) Changed the Directory label to a textbox so you can modify the save directory in the textBox instead of having to use the Folder dialog box every time 4) Also if you type in a directory that does not exist into the TextBox, then it will try to create it (note I'm not yet catching any exceptions that might occur here so if you screw up the directory, it could close Paint .NET) See first post in this topic for the download Edited December 8, 2010 by recursor Quote Link to post Share on other sites
lolgg 0 Posted December 9, 2010 Share Posted December 9, 2010 (edited) Hi recursor, Just wanted to say thanks for the plugin, and also ask about it. The video tutorial didn't really specify how to actually create an animation, could you give me some help with that? I don't really understand the column thing - it says the number of columns per row to use for the anim, but I only want to use the images from 1 row. Is it just going to take the number of images I specify from that row? When I put the column as 1, and frames as 2, should I be expecting a static image? Because I'm getting the same image moving up and down. I randomly tried some settings and the animation kept making the guy go off the image. Is there any way to make it just a walking animation like in your video? I don't want him to go off screen. Edited December 9, 2010 by lolgg Quote Link to post Share on other sites
recursor 10 Posted December 11, 2010 Author Share Posted December 11, 2010 Hi recursor, Just wanted to say thanks for the plugin, and also ask about it. The video tutorial didn't really specify how to actually create an animation, could you give me some help with that? I don't really understand the column thing - it says the number of columns per row to use for the anim, but I only want to use the images from 1 row. Is it just going to take the number of images I specify from that row? When I put the column as 1, and frames as 2, should I be expecting a static image? Because I'm getting the same image moving up and down. I randomly tried some settings and the animation kept making the guy go off the image. Is there any way to make it just a walking animation like in your video? I don't want him to go off screen. If you only have one row then all you need to do is make sure that the # of columns specified is equal to or greater than the number of frames you have and you'll be ok. If however, your animation spans more than 1 row, then you can use the columns to indicate when the program should go to the next row. Ex: Let's say I have 7 frames in my animation, but I have 4 on the 1st row and 3 on the next row as shown below: [1] [2] [3] [4] [5] [6] [7] In this case, you would set columns = 4 and the frames=7. When the program goes to get the 5th frame it knows that there are only 4 frames per row so it goes to the next row to get the 5th, 6th, and 7th frames. Also, if you have a grid between each cell as shown in my video, then you will want to set the Border equal to the width of those pixels so that they will be skipped. If you have no borders on your frames then be sure to set Border=0. If your animation moves left or right, then any of the following may be the culprit: Your cell width/height (the size of each frame) Your starting offset in the image Your border size may be wrong This may require another video to explain more clearly... Quote Link to post Share on other sites
dsv101 0 Posted December 15, 2010 Share Posted December 15, 2010 Paint dot net crashes when i try to use this add on. It shows the Animation helper right before an error message/crash heres a link to the crash report file, the forum says im not permitted to attach text files, probably because its a log, luckily i have dropbox. Quote Link to post Share on other sites
recursor 10 Posted December 15, 2010 Author Share Posted December 15, 2010 Ok. I think I've fixed that bug. See The first post in this topic for version 0.81 or the plugin. Quote Link to post Share on other sites
dsv101 0 Posted December 17, 2010 Share Posted December 17, 2010 Ok. I think I've fixed that bug. See The first post in this topic for version 0.81 or the plugin. thanks! works great, this will be handy for me during the ludum dare game making competition this weekend! ludum dare!! Quote Link to post Share on other sites
seekercat 0 Posted December 21, 2010 Share Posted December 21, 2010 I really wanna use this, but every time I try to run it, the Animation Helper box will appear, then an error message will pop up saying paint.net needs to close. It then closes and creates this log. Quote Link to post Share on other sites
Supermini_man 0 Posted December 24, 2010 Share Posted December 24, 2010 (edited) Major props to the creator of this plugin. I always created animations inside the game engine I use (Game Maker 8 Pro), but now this will make the whole process more convenient. I've consider Promotion in the past, but it's so complicated, while this is perfect to me. Edited December 24, 2010 by Supermini_man Quote Artist/Game Developer/Traveller DeviantARTGame Jolt Profile Link to post Share on other sites
desirez 0 Posted July 13, 2011 Share Posted July 13, 2011 Ok. I think I've fixed that bug. See The first post in this topic for version 0.81 or the plugin. Still crashes for me. Here's the error: Exception details: System.NullReferenceException: Object reference not set to an instance of an object. at AnimationEffect.AnimationHelper.SetFrameNumber(Int32 frame) at AnimationEffect.AnimationHelper.timer_Tick(Object sender, EventArgs e) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Quote Link to post Share on other sites
recursor 10 Posted July 27, 2011 Author Share Posted July 27, 2011 (edited) Still crashes for me. Here's the error: Exception details: System.NullReferenceException: Object reference not set to an instance of an object. at AnimationEffect.AnimationHelper.SetFrameNumber(Int32 frame) at AnimationEffect.AnimationHelper.timer_Tick(Object sender, EventArgs e) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Sorry I took so long to respond. I just saw this today. While I have been unable to reproduce this, I think I see what might have caused it. Version 0.83 should fix the problem. Edited July 31, 2011 by recursor Quote Link to post Share on other sites
amitsri 0 Posted August 30, 2011 Share Posted August 30, 2011 I have downloaded your latest plugin dll. Everything is working fine, except one error when pressing Save frames without entering the Target folder path. This cause paint.net to crashed and closed. Please fix this issue by validating the target folder path on clicking Save Frames. I have also attached the crash log. Thanks pdncrash.zip Quote Link to post Share on other sites
NisseBosseLasse 0 Posted September 4, 2011 Share Posted September 4, 2011 (edited) I'm using it now! Thanks for sharing. EDIT: one thing that I'd find useful is buttons next to "Offset" that increases the offset in X or Y by the current width or height of the cell. That is, if the cells are set to be 32x64, the "Next" button next to "Offset X" would increase the current X offset by 32 (and the "Next" button next to "Offset Y" would increase the current Y offset by 64). Edited September 4, 2011 by NisseBosseLasse Quote Link to post Share on other sites
LiveLongDieHard 0 Posted September 10, 2011 Share Posted September 10, 2011 (edited) <snip - no need to quote the whole first post > When i use this my image is always small. If i make it larger in the plugin it starts to show other images from other sprites around it. Please help me. Edited September 11, 2011 by Ego Eram Reputo Quote Quote Me when you reply please. Link to post Share on other sites
