Sprite Animation Helper (v 1.0.1.3 updated April 30, 2022)
recursor
7 hours ago, BitFlip said:
I really like Sprite Animation Helper, I just wish it would add a zero to the named frames if they happen to be more than 10, as it is now I have to manually rename the files so that they end up in the right order (2 being interpreted as a higher number than 10; but 02 wouldn't be).
Since it is activly being worked on I really hope that could get implemented some day.
Is this not a nuisance for anyone else? Or do you solve it in some other way?
Just implemented your sugestion in v1.0.0.96 which adds zero padding as needed to frame numbers when exporting individual frames.
  • Like 2
  • Upvote 2
  • 2 years later...
  • 3 months later...
  • 4 weeks later...
On 12/13/2020 at 6:11 AM, Pixey said:
Hello @Klink75 and welcome :)
In the animation tutorial the author shows you how to use 'PingPong' by checking the box.
Hi Pixey! I actually have the exact same question as Klink75. I see how to toggle on the "PingPong" option by checking the box, however when I go to Export, it exports without PingPonging the image. It goes frame 12341234 rather than 1234321. Do you know if there is a way to keep PingPong applied when exporting and not just previewing?
Thanks!
I'll look into this tomorrow for you @mackenzieg :)
Meanwhile I made my first spite gif with his Plugin:   shooting-man.gif    ninja.gif
On 3/13/2021 at 3:40 PM, Hiddena0 said:
When I try to use it, the window defaults to a small size and when I expand it, it stays small.
@Hiddena0 when you are in the animate box, be sure to use the Zoom and when you save it, click that you want it zoomed, then you'll have a bigger image :)
Hi @mackenzieg I think if you are looking to save the layers the Ping Pong creates, which seems to be that it goes to the end of the line and then goes backwards, would be to use Paint.net for this.
The best way would be to make your Gif first in Ping Pong mode, then go to the saved Gif and add this code after the title = .agif.  Then open Paint.net and import the .agif and it will open up in the layers you made with the ping pong.  It will look like this:
   < Clickable >
You can then re-animate it with @midora's Animate Plugin if you want to.  You would have to, though, do the layers from 1 - 16 backwards.  I believe there is a way to this inside of File Explorer.
Hope this helps you.
  • recursor changed the title to Sprite Animation Helper (v 1.0.1.0 updated October 19,2021)
@recursor FYI this plugin isn't working so well at high-DPI, this is just at 144 dpi / 150% scaling ...
Also it would be smart to add a PluginSupportInfo that contains a WebsiteUri so that the error message in Paint.NET can help guide people where to download the updated version. As it is, since I have to block the old versions (due to the incompatibility with .NET 5), people may not know what to do.
  • recursor changed the title to Sprite Animation Helper (v 1.0.1.1 updated March 11,2022)
 The latest version adds PluginSupportInfo and now plays more nicely with DPI scaling (from my testing).
  • Like 3
  • Upvote 2
11 hours ago, Rasterisko said:
But after the update of Paint.net to the version 4.3.10 the plugin crashs if I try to export like a individual frame or frame stripe and the Paint.net closes.
I will try to test this.  Did you update the plugin?  I notice a newer version available on page 1 on 3/11/22.
Hello, Recursor. First, thanks a lot for the plugin. I love it! 😍
If you have a crash log, please post it
@Rick Brewster It is saving as a Gif, but crashing upon trying to save as individual frames:
Spoiler
This text file was created because paint.net crashed. Please e-mail this to <email removed> so we can diagnose and fix the problem.
Application version: paint.net 4.3.10 (Stable 4.310.8103.32785)
Time of crash: 4/22/2022 12:26:10 PM
Application uptime: 00:06:43.4565941
Application state: Running
Working set: 261,108 KiB
Handles and threads: 1617 handles, 39 threads, 331 gdi, 299 user
Install type: Classic
Application directory: C:\Program Files\paint.net
Current directory: C:\Program Files\paint.net
Install directory: C:\Program Files\paint.net
OS Version: Windows 10 Home 10.0.19043.0 x64
.NET version: .NET 6.0.3 x64
Processor: "Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz" @ ~2494MHz (2C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX)
Physical memory: 8094 MB
Video card: Intel(R) HD Graphics 4000 (v:8086, d:166, r:9), Microsoft Basic Render Driver (v:1414, d:8C, r:0)
Hardware acceleration: True (default: True)
Remote session: no
Pointers: none
UI animations: True
UI DPI: 96 dpi (1.00x scale)
UI theme: VisualStyleCategory=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Light, ThemeFileName=Aero.msstyles
Updates: True, 4/22/2022 (journal: ShouldCheckForUpdate, CheckedForUpdate)
Flags:
Exception details:
System.Security.AccessControl.PrivilegeNotHeldException: The process does not possess the 'SeSecurityPrivilege' privilege which is required for this operation.
   at System.Security.AccessControl.Win32.GetSecurityInfo(ResourceType resourceType, String name, SafeHandle handle, AccessControlSections accessControlSections, RawSecurityDescriptor& resultSd)
   at System.Security.AccessControl.NativeObjectSecurity.CreateInternal(ResourceType resourceType, Boolean isContainer, String name, SafeHandle handle, AccessControlSections includeSections, Boolean createByName, ExceptionFromErrorCode exceptionFromErrorCode, Object exceptionContext)
   at Pixelbyte.AnimationEffect.AnimationHelper.HasWriteAccessToFolder(String path)
   at Pixelbyte.AnimationEffect.AnimationHelper.SaveIndividualFrames(String frameFilename, ImageFormat imgFormat)
   at Pixelbyte.AnimationEffect.AnimationHelper.btnSaveFrames_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
Managed assemblies:
    System.Private.CoreLib, .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet, .\paintdotnet.dll, Version=4.310.8103.32785
    System.Runtime, .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base, .\PaintDotNet.Base.dll, Version=4.310.8103.32785
    System.Windows.Forms, .\System.Windows.Forms.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.Process, .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    TerraFX.Interop.Windows, .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.SystemLayer, .\PaintDotNet.SystemLayer.dll, Version=4.310.8103.32785
    System.Runtime.InteropServices.RuntimeInformation, .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.InteropServices, .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer.Native.x64, .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.310.8103.32785
    System.Threading, .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Extensions, .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC, .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric, .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Intrinsics, .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Core, .\PaintDotNet.Core.dll, Version=4.310.8103.32785
    System.Private.Uri, .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives, .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    WindowsBase, .\WindowsBase.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms.Primitives, .\System.Windows.Forms.Primitives.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
    System.Drawing.Primitives, .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework, .\PresentationFramework.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
    System.Xaml, .\System.Xaml.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
    System.ComponentModel, .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource, .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections, .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread, .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages, .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives, .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Resources, .\PaintDotNet.Resources.dll, Version=4.310.8103.32785
    System.ObjectModel, .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data, .\PaintDotNet.Data.dll, Version=4.310.8103.32785
    System.Configuration.ConfigurationManager, .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Specialized, .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Framework, .\PaintDotNet.Framework.dll, Version=4.310.8103.32785
    System.Xml.ReaderWriter, .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml, .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.WebClient, .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ComponentModel.EventBasedAsync, .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.SystemEvents, .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Drawing.Common, .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Immutable, .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory, .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Threading.ThreadPool, .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq, .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.Extensions, .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Registry, .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Concurrent, .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows, .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims, .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.TypeConverter, .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationCore, .\PresentationCore.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
    DirectWriteForwarder, .\DirectWriteForwarder.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
    System.Diagnostics.Debug, .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    UIAutomationTypes, .\UIAutomationTypes.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35
    System.Diagnostics.FileVersionInfo, .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects, .\PaintDotNet.Effects.dll, Version=4.310.8103.32785
    Accessibility, .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Threading.Tasks.Parallel, .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Packaging, .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Numerics.Vectors, .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Loader, .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    DdsFileTypePlus, .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.11.0
    WebPFileType, .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.11.0
    AvifFileType, .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.19.0
    System.Diagnostics.Tracing, .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Mono.Cecil, .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard, .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Reflection.MetadataLoadContext, .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Reflection.Metadata, .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles, .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Plugins.Compatibility, .\PaintDotNet.Plugins.Compatibility.dll, Version=4.310.8103.32785
    System.Console, .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Crc32.NET, .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99
    System.Security.Cryptography.Primitives, .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Pixelbyte.AnimationEffect, .\Effects\Pixelbyte.AnimationEffect.dll, Version=1.0.1.1
    System.Resources.Extensions, .\System.Resources.Extensions.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Drawing, .\System.Drawing.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a
    WhatIsIt.Effect, .\Effects\WhatIsIt.Effect.dll, Version=0.1.0.111
    PSFilterPdn, .\Effects\PSFilterPdn.dll, Version=1.0.8.2
    mscorlib, .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    Twist, C:\Users\Nanette\Documents\paint.net App Files\Effects\Twist.dll, Version=4.0.5873.25056
    Borders N' Shapes, C:\Users\Nanette\Documents\paint.net App Files\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476
    System, .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Core, .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    Color Match, C:\Users\Nanette\Documents\paint.net App Files\Effects\Color Match.dll, Version=4.2.7630.21216
    Film, C:\Users\Nanette\Documents\paint.net App Files\Effects\Film.dll, Version=4.0.4642.26607
    Trail, C:\Users\Nanette\Documents\paint.net App Files\Effects\Trail.dll, Version=4.0.4642.26791
    Stitch, C:\Users\Nanette\Documents\paint.net App Files\Effects\Stitch.dll, Version=4.0.4642.26808
    Curves+, C:\Users\Nanette\Documents\paint.net App Files\Effects\Curves+.dll, Version=4.0.6119.31044
    Gradient Mapping, C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Mapping.dll, Version=4.0.6547.33963
    System.Runtime.Serialization.Formatters, .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Gradient Blocks, C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Blocks.dll, Version=4.0.4642.26658
    Gradient Bars, C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Bars.dll, Version=4.0.5152.23084
    Gradient Grid, C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Grid.dll, Version=4.0.6436.36068
    Jitter, C:\Users\Nanette\Documents\paint.net App Files\Effects\Jitter.dll, Version=4.0.4642.26986
    Liquify, C:\Users\Nanette\Documents\paint.net App Files\Effects\Liquify.dll, Version=4.0.5873.25113
    Splatter, C:\Users\Nanette\Documents\paint.net App Files\Effects\Splatter.dll, Version=4.0.5873.25083
    Outline Object, C:\Users\Nanette\Documents\paint.net App Files\Effects\Outline Object.dll, Version=4.0.4642.26954
    Pixelate+, C:\Users\Nanette\Documents\paint.net App Files\Effects\Pixelate+.dll, Version=4.0.4642.26940
    Random Effect, C:\Users\Nanette\Documents\paint.net App Files\Effects\Random Effect.dll, Version=4.0.4642.26928
    Random Shape Fill, C:\Users\Nanette\Documents\paint.net App Files\Effects\Random Shape Fill.dll, Version=4.0.4642.26910
    Grid Warp, C:\Users\Nanette\Documents\paint.net App Files\Effects\Grid Warp.dll, Version=4.0.6544.34496
    System.Text.RegularExpressions, .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Smudge, C:\Users\Nanette\Documents\paint.net App Files\Effects\Smudge.dll, Version=4.0.5873.25097
    System.CodeDom, .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Newtonsoft.Json, .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Linq.Expressions, .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Planetoid, .\Effects\Planetoid.dll, Version=1.0.4.0
    DHShapeMaker, .\Effects\DHShapeMaker.dll, Version=1.7.0.1
    System.Runtime.Numerics, .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.Unsafe, .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Http, .\System.Net.Http.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Primitives, .\System.Net.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.DiagnosticSource, .\System.Diagnostics.DiagnosticSource.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.Security, .\System.Net.Security.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Cryptography.X509Certificates, .\System.Security.Cryptography.X509Certificates.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Sockets, .\System.Net.Sockets.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Overlapped, .\System.Threading.Overlapped.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.NameResolution, .\System.Net.NameResolution.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.StackTrace, .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Cryptography.Encoding, .\System.Security.Cryptography.Encoding.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml.Linq, .\System.Private.Xml.Linq.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.IO.Compression, .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089
    K4os.Compression.LZ4, .\K4os.Compression.LZ4.dll, Version=1.2.15.0, PublicKeyToken=2186fa9121ef231d
    PresentationFramework-SystemXmlLinq, .\PresentationFramework-SystemXmlLinq.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089
    System.Xml.XDocument, .\System.Xml.XDocument.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.Linq, .\System.Xml.Linq.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Security.Cryptography.Algorithms, .\System.Security.Cryptography.Algorithms.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.XmlSerializer, .\System.Xml.XmlSerializer.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.FileSystem.AccessControl, .\System.IO.FileSystem.AccessControl.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.AccessControl, .\System.Security.AccessControl.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
Native modules:
    .\paintdotnet.exe, version=4.310.8103.32785
    C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1645 (WinBuild.160101.0800)
    C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.964 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    .\hostfxr.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
    .\hostpolicy.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
    .\coreclr.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
    C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    C:\WINDOWS\System32\combase.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800)
    .\System.Private.CoreLib.dll, version=6.0.322.12309
    .\clrjit.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
    C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    .\paintdotnet.dll, version=4.310.8103.32785
    .\System.Runtime.dll, version=6.0.322.12309
    C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\PaintDotNet.Base.dll, version=4.310.8103.32785
    .\System.Windows.Forms.dll, version=6.0.322.12307
    .\System.Diagnostics.Process.dll, version=6.0.322.12309
    .\TerraFX.Interop.Windows.dll, version=10.0.20348.0
    .\PaintDotNet.SystemLayer.dll, version=4.310.8103.32785
    .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.322.12309
    .\System.Runtime.InteropServices.dll, version=6.0.322.12309
    .\vcruntime140.dll, version=14.31.31103.0
    .\vcruntime140_1.dll, version=14.31.31103.0
    .\msvcp140.dll, version=14.31.31103.0
    .\msvcp140_1.dll, version=14.31.31103.0
    .\msvcp140_2.dll, version=14.31.31103.0
    .\msvcp140_codecvt_ids.dll, version=14.31.31103.0
    .\vcomp140.dll, version=14.31.31103.0
    .\ijwhost.dll, version=6,0,322,12309 @Commit: c24d9a9c91c5d04b7b4de71f1a9f33ac35e09663
    .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.310.8103.32785
    C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1645_none_91a2a668cc89980b\gdiplus.dll, version=10.0.19041.1645 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Threading.dll, version=6.0.322.12309
    .\System.Runtime.Extensions.dll, version=6.0.322.12309
    .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.322.12309
    .\System.Collections.NonGeneric.dll, version=6.0.322.12309
    .\System.Runtime.Intrinsics.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\shlwapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\PaintDotNet.Core.dll, version=4.310.8103.32785
    .\System.Private.Uri.dll, version=6.0.322.12309
    .\System.ComponentModel.Primitives.dll, version=6.0.322.12309
    .\WindowsBase.dll, version=6.0.322.12402
    .\System.Windows.Forms.Primitives.dll, version=6.0.322.12307
    .\System.Drawing.Primitives.dll, version=6.0.322.12309
    .\PresentationFramework.dll, version=6.0.322.12402
    .\System.Xaml.dll, version=6.0.322.12402
    .\System.ComponentModel.dll, version=6.0.322.12309
    .\System.Diagnostics.TraceSource.dll, version=6.0.322.12309
    .\System.Collections.dll, version=6.0.322.12309
    .\System.Threading.Thread.dll, version=6.0.322.12309
    .\System.Text.Encoding.CodePages.dll, version=6.0.322.12309
    .\Microsoft.Win32.Primitives.dll, version=6.0.322.12309
    .\PaintDotNet.Resources.dll, version=4.310.8103.32785
    .\System.ObjectModel.dll, version=6.0.322.12309
    .\PaintDotNet.Data.dll, version=4.310.8103.32785
    .\PresentationNative_cor3.dll, version=6,0,22,10402 @Commit: 962ab77e3d043ec9377feec32e1b26824338e9db
    .\System.Configuration.ConfigurationManager.dll, version=6.0.322.12309
    .\System.Collections.Specialized.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800)
    .\PaintDotNet.Framework.dll, version=4.310.8103.32785
    .\System.Xml.ReaderWriter.dll, version=6.0.322.12309
    .\System.Private.Xml.dll, version=6.0.322.12309
    .\System.Net.WebClient.dll, version=6.0.322.12309
    .\System.ComponentModel.EventBasedAsync.dll, version=6.0.322.12309
    .\Microsoft.Win32.SystemEvents.dll, version=6.0.322.12309
    C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Drawing.Common.dll, version=6.0.322.12309
    .\System.Collections.Immutable.dll, version=6.0.322.12309
    .\System.Memory.dll, version=6.0.322.12309
    .\System.Threading.ThreadPool.dll, version=6.0.322.12309
    .\System.Linq.dll, version=6.0.322.12309
    .\System.Text.Encoding.Extensions.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    .\Microsoft.Win32.Registry.dll, version=6.0.322.12309
    .\System.Collections.Concurrent.dll, version=6.0.322.12309
    .\System.Security.Principal.Windows.dll, version=6.0.322.12309
    .\System.Security.Claims.dll, version=6.0.322.12309
    .\System.ComponentModel.TypeConverter.dll, version=6.0.322.12309
    .\PresentationCore.dll, version=6.0.322.12402
    .\DirectWriteForwarder.dll, version=6,0,322,12402 @Commit: 560f243910f407df33fd5cdf06e2a857684f4bc7
    .\System.Diagnostics.Debug.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\UIAutomationTypes.dll, version=6.0.322.12402
    .\System.Diagnostics.FileVersionInfo.dll, version=6.0.322.12309
    .\PaintDotNet.Effects.dll, version=4.310.8103.32785
    .\Accessibility.dll, version=6.0.322.12307
    .\System.Threading.Tasks.Parallel.dll, version=6.0.322.12309
    .\System.IO.Packaging.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    .\System.Numerics.Vectors.dll, version=6.0.322.12309
    .\ucrtbase.dll, version=10.0.22000.194 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800)
    .\System.Runtime.Loader.dll, version=6.0.322.12309
    .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.11.0
    .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.11.0
    .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.19.0
    C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.1466 (WinBuild.160101.0800)
    C:\Windows\System32\WinTypes.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\TextShaping.dll, version=
    .\System.Diagnostics.Tracing.dll, version=6.0.322.12309
    .\Mono.Cecil.dll, version=0.11.4.0
    .\netstandard.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210
    C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800)
    .\System.Reflection.Metadata.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    .\System.IO.MemoryMappedFiles.dll, version=6.0.322.12309
    .\PaintDotNet.Plugins.Compatibility.dll, version=4.310.8103.32785
    .\System.Console.dll, version=6.0.322.12309
    .\Crc32.NET.dll, version=1.2.0.5
    .\System.Security.Cryptography.Primitives.dll, version=6.0.322.12309
    .\Effects\Pixelbyte.AnimationEffect.dll, version=1.0.1.1
    .\System.Resources.Extensions.dll, version=6.0.322.12309
    .\System.Drawing.dll, version=6.0.322.12307
    .\Effects\WhatIsIt.Effect.dll, version=0.1.0.111
    .\Effects\PSFilterPdn.dll, version=1.0.8.2
    .\mscorlib.dll, version=6.0.322.12309
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Twist.dll, version=4.0.5873.25056
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Borders N' Shapes.dll, version=4.0.4642.26476
    .\System.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Core.dll, version=6.0.322.12309
    C:\Program Files\McAfee\MfeAV\AMSIExt.dll, version=26.0.144 9c8b9018 smoldering cucumber
    C:\WINDOWS\System32\PSAPI.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Color Match.dll, version=4.2.7630.21216
    C:\Program Files\Common Files\McAfee\Platform\Core\mccoreps.dll, version=14,5,118,0
    C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Film.dll, version=4.0.4642.26607
    .\System.Runtime.Serialization.Formatters.dll, version=6.0.322.12309
    C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.1415 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Trail.dll, version=4.0.4642.26791
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Stitch.dll, version=4.0.4642.26808
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Curves+.dll, version=4.0.6119.31044
    C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Program Files\Common Files\McAfee\Platform\core\vtploader.dll, version=14,5,118,0
    C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800)
    C:\Program Files\Common Files\McAfee\SystemCore\mfevtpa.dll, version=SYSCORE.22.2.0.148
    C:\Program Files\Common Files\McAfee\SystemCore\mfehida.dll, version=SYSCORE.22.2.0.148
    C:\Program Files\Common Files\McAfee\SystemCore\mfemmsa.dll, version=SYSCORE.22.2.0.148
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Blocks.dll, version=4.0.4642.26658
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Bars.dll, version=4.0.5152.23084
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Gradient Grid.dll, version=4.0.6436.36068
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Jitter.dll, version=4.0.4642.26986
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Liquify.dll, version=4.0.5873.25113
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Splatter.dll, version=4.0.5873.25083
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Outline Object.dll, version=4.0.4642.26954
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Grid Warp.dll, version=4.0.6544.34496
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Pixelate+.dll, version=4.0.4642.26940
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Random Effect.dll, version=4.0.4642.26928
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Random Shape Fill.dll, version=4.0.4642.26910
    C:\Users\Nanette\Documents\paint.net App Files\Effects\Smudge.dll, version=4.0.5873.25097
    .\System.CodeDom.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Text.RegularExpressions.dll, version=6.0.322.12309
    C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546
    C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746
    C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\UMPDC.dll, version=
    .\Newtonsoft.Json.dll, version=13.0.1.25517
    .\System.Linq.Expressions.dll, version=6.0.322.12309
    .\System.Runtime.Numerics.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.19041.746 (WinBuild.160101.0800)
    .\System.Net.Http.dll, version=6.0.322.12309
    .\System.Net.Primitives.dll, version=6.0.322.12309
    .\System.Diagnostics.DiagnosticSource.dll, version=6.0.322.12309
    .\System.Net.Security.dll, version=6.0.322.12309
    .\System.Security.Cryptography.X509Certificates.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\iphlpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\NSI.dll, version=10.0.19041.610 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\winhttp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Net.Sockets.dll, version=6.0.322.12309
    C:\WINDOWS\system32\mswsock.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\wshunix.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Threading.Overlapped.dll, version=6.0.322.12309
    .\System.Net.NameResolution.dll, version=6.0.322.12309
    C:\WINDOWS\System32\winrnr.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Windows\System32\rasadhlp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\system32\wshbth.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\system32\NLAapi.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    C:\WINDOWS\system32\pnrpnsp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\napinsp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    .\System.Diagnostics.StackTrace.dll, version=6.0.322.12309
    C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.19041.1503 (WinBuild.160101.0800)
    .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc
    C:\WINDOWS\SYSTEM32\sspicli.dll, version=10.0.19041.1586 (WinBuild.160101.0800)
    C:\WINDOWS\system32\schannel.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\mskeyprotect.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\ncryptsslp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    .\System.Security.Cryptography.Encoding.dll, version=6.0.322.12309
    C:\WINDOWS\SYSTEM32\igd10iumd64.dll, version=10.18.10.5161
    C:\WINDOWS\SYSTEM32\igdusc64.dll, version=10.18.10.5161
    .\System.Private.Xml.Linq.dll, version=6.0.322.12309
    C:\WINDOWS\System32\comdlg32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DUI70.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DUser.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\thumbcache.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.UI.FileExplorer.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\System32\StructuredQuery.dll, version=7.0.19041.867 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\atlthunk.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\iertutil.dll, version=11.00.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\Windows.Storage.Search.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\twinapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\coml2.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\LINKINFO.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ntshrui.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\srvcli.dll, version=10.0.19041.1645 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\cscapi.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Windows\System32\MrmCoreR.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\windows.staterepositorycore.dll, version=10.0.19041.1466 (WinBuild.160101.0800)
    C:\Windows\System32\bcp47mrm.dll, version=10.0.19041.1503 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.UI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\WindowManagementAPI.dll, version=
    C:\Windows\System32\InputHost.dll, version=10.0.19041.906 (WinBuild.160101.0800)
    C:\Windows\System32\ActXPrxy.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Users\Nanette\AppData\Local\Microsoft\OneDrive\22.065.0412.0004\FileSyncShell64.dll, version=22.065.0412.0004
    C:\WINDOWS\SYSTEM32\WININET.dll, version=11.00.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\Secur32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\Windows\System32\EhStorShell.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\cldapi.dll, version=10.0.19041.1288 (WinBuild.160101.0800)
    C:\Windows\System32\FLTLIB.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MPR.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\drprov.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ntlanman.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\davclnt.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DAVHLPR.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\System32\wkscli.dll, version=10.0.19041.1645 (WinBuild.160101.0800)
    C:\WINDOWS\System32\netutils.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    C:\WINDOWS\system32\NetworkExplorer.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\provsvc.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    C:\Windows\System32\OneCoreUAPCommonProxyStub.dll, version=10.0.19041.1620 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\PhotoMetadataHandler.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    .\System.IO.Compression.dll, version=6.0.322.12309
    .\K4os.Compression.LZ4.dll, version=1.2.15
    C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    .\PresentationFramework-SystemXmlLinq.dll, version=6.0.322.12402
    .\System.Xml.XDocument.dll, version=6.0.322.12309
    .\System.Xml.Linq.dll, version=6.0.322.12309
    .\System.Security.Cryptography.Algorithms.dll, version=6.0.322.12309
    .\System.Xml.XmlSerializer.dll, version=6.0.322.12309
    C:\WINDOWS\System32\urlmon.dll, version=11.00.19041.1 (WinBuild.160101.0800)
    .\System.IO.FileSystem.AccessControl.dll, version=6.0.322.12309
    .\System.Security.AccessControl.dll, version=6.0.322.12309
  • Thanks 1
  • recursor changed the title to Sprite Animation Helper (v 1.0.1.3 updated April 30, 2022)
1 hour ago, recursor said:
3 but forgot to update the information on this post. Sorry about that.
Edited by recursor
Thank you very much :)
