ambertape Posted December 22, 2009 Share Posted December 22, 2009 I have several . Net framework versions loaded in add/remove programs namely .net framerwork 1.1 and security update .net framework 2.0 sp2 and a lot of updates like .asp. net etc .net framework 3.0 sp 2 and eleven updates and finally .net framework 3.0 sp1 and hotfix for microsoft .net framework 3.5 sp2 (KB953595) Could the old versions be causing the program to close encountering a problem ? Would like to try this program but can't get it working. What can I try to get it working ? Thanks Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 22, 2009 Share Posted December 22, 2009 Does Add/Remove programs show Microsoft .NET Framework 3.5 sp1? It is required. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 22, 2009 Share Posted December 22, 2009 If you don't have .NET 3.5 SP1 installed, then you need to install it. It's a free download from Microsoft, a link can be found here: http://www.getpaint.net/download.html Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
ambertape Posted December 22, 2009 Author Share Posted December 22, 2009 Add/remove programs shows .net framework 3.5 sp1. might earlier versions be conflicting with paint.net ? I have reinstalled and uninstalled 3 X .net framework and paint.net but keep getting same problem "encountering a problem and must shut down" Look forward to your help to try your program. Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 23, 2009 Author Share Posted December 23, 2009 what steps do I try to get paint.net working instead of closing immediately when I click on open pictures ? Something is causing your program to close . Thanks Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 23, 2009 Share Posted December 23, 2009 ambertape, You could try running this: Program Files\Paint.NET\PdnRepair Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 24, 2009 Author Share Posted December 24, 2009 Hi, I ran Pdnrepair, it stated success yet when I go to open a jpg file, it states encountering a problem and must close Paint.net. I am open to other suggestions. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 24, 2009 Share Posted December 24, 2009 ambertape, Please say what OS version you are using, XP, Vista, etc. Also, what OS Service Pack level you have installed, and whether you are fully current on Windows Updates. Please make a screenshot of the error message and post it here. Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 25, 2009 Author Share Posted December 25, 2009 I am using XP Pro SP2 with 2 gb of memory. I have all the latest updates but I believe I have a weird problem that effects me using paint.net as well as Microsoft Paint. I tried many many times to open a screen I saved and it automatically closed down just like when I ran paint.net so somewhere my problem effects both programs. I ran a virus program, Microsoft security essentials and although it found some viruses, it removed all of them. The bottom line something is happening in my system. The only way I was able to save the many screens was to paste them into PowerPoint. I am sending you these files and hope you will be able to figure out what my problem is. Since the powerpoint files aren't acceptable I converted all the files into png format and these files were acceptable . Thanks a lot. Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 25, 2009 Author Share Posted December 25, 2009 here are the other two files. Evidently this program has a limit of three attachments. Thanks. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 25, 2009 Share Posted December 25, 2009 ambertape, The problem derives from a video codec. viscommpgdec.dll Be sure to Open and Save from a directory with no video files inside it. Here's a link to a site with some possible help to eliminate the problem. http://wer.microsoft.com/Responses/Resp ... c701e#here Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 27, 2009 Author Share Posted December 27, 2009 I found the offending file and sent a email to the software vendor Free Video Converter. I uninstalled this program for the time being. So I print a screen did a pr int screen, pasted it into Paint and was able to save it, open the file but I have a new problem that I can't install your program. I don't know why but I am enclosing the file I was just able to save. The email server of Compuserve isn't working for the last two days. Please answer me at ambertape@hotmail.com if possible. Compuserve doesn't know when they will have the mail server fixed so please answer me to both email addresses. Thanks. Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 29, 2009 Author Share Posted December 29, 2009 Compuserve is up.I look forward to your reply so I can try your program. Thanks Ambertape Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 29, 2009 Share Posted December 29, 2009 Go back to Add/Remove Programs and run the repair option on NET Framework v. 2.0. Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 29, 2009 Author Share Posted December 29, 2009 I didn't see the word repair but the word change so I clicked on it and then when I went to reinstall it again, I believe I got the same error as per enclosed file. Compuserve is working again. Should I delete net framework 2.0 sp2 and reinstall it ? tHANKS Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 30, 2009 Author Share Posted December 30, 2009 Might it be an idea toi remove all versions of .Net Framework and then reinstall them providing I could find them on the Microsoft ownload website ? I would like to test your program. Look forward to your reply. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 30, 2009 Share Posted December 30, 2009 (edited) ambertape, I'm not sure what happens when you click on "Change". To do the Repair option, click on the NET Framework listing, then on "Click here for support information." A window with a repair option should open up. ================ Uninstalling and re-installing may solve things, give it a try. ================ Also, try doing a command line chkdsk scan with the /f parameter, as described here: chkdsk with /f parameter Let it complete, then do a screenshot to post here. Edited April 7, 2010 by Sarkut Quote Link to comment Share on other sites More sharing options...
ambertape Posted December 31, 2009 Author Share Posted December 31, 2009 Hi, I seem to be running into additional problems. I ran chkdsk/f but I didn't see the screen as I had a phone call and was away from my laptop. I am enclosing two .png files showing my problems. I couldn't repair the .net framework 2.0 so I decided to download ver 2.0. Unfortunately the file I downloaded was dosnetfx.exe and it asked for a a msi file which I didn't find on Microsoft only exe files. Bottom line I couldn't install the exe file and I didn't find netfx20a_X86.msi. I also can't remove framework 2.0 either so I need more help. I read about a cleanup tool for all the framework files by a Microsoft person named Aaron Stebner Web. Look forward to your answers. Thanks. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 31, 2009 Share Posted December 31, 2009 Check to see if you have "Microsoft .NET Framework 3.0" or 3.5 below the entry for 2.0. The error you're getting is because there are other items in Add/Remove Programs that are dependent on 2.0. The .NET Framework stuff is confusing, so don't be too concerned if you're confused. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
ambertape Posted December 31, 2009 Author Share Posted December 31, 2009 I will stay with it even though the trouble shooting is weird because I have heard many nice things about your program. I took two snapshots of the stuff I have listed in add/change programs. Hope it helps . Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 31, 2009 Share Posted December 31, 2009 So, the NET Frameworks should be uninstalled in descending numerical order. NET 3.5 SP1 first. NET 3.0 SP2 next. Then NET 2.0 SP2. And, reinstalled in ascending numerical order. Quote Link to comment Share on other sites More sharing options...
ambertape Posted January 1, 2010 Author Share Posted January 1, 2010 I can't remove the remove these files. It won't let me let me remove 2.0 sp2, 3.0 sp2 and 3.5 sp2. So far I can't delete any of the .net framework files. Need another suggestion. Might it be possible to remove them in the registry ? Have a Happy New Year Ambertape Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 1, 2010 Share Posted January 1, 2010 ambertape, tip: don't use ' in file names. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
ambertape Posted January 4, 2010 Author Share Posted January 4, 2010 Would it pay to use the tool below to clean up all the .net framework versions and then reinstall them as per your earlier instructions ? Are all versions available for downloading ? Aaron Stebners tool .NET Framework Cleanup Tool 6.0.3790 thanks ambertape Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 4, 2010 Share Posted January 4, 2010 Don't know. I've never tried that tool. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
