Posted
After I got the newer version I noticed now that a couple of my fonts dont work with it and cause it to crash. If there is a way to remove these fonts or make paint.net work with them it would allow me to scroll through my fonts once again.. :(
23529_fd143f6b7e26fbf1076e9757ca630397
pdncrash.log
Posted
In Paint.NET's menu bar, Utilities > Manage fonts...
It will open your Windows Fonts folder.
You can remove fonts from there if you wish to.
See thats my problem the fonts that dont seem to be working right dont appear in the fonts folder. so is there a way to fix the issue in paint.net to enable it to read them?
Posted
Very strange.
These fonts show up and work okay in your word-processor - Word Pad or whatever?
You might try going to your Folder Options and ticking Show Hidden Files and Folders.
See whether that makes them show up in the Fonts directory.
The fonts not showing in the Fonts folder seems to point to a font
problem rather than a PdN problem.
If they don't show in the folder there may be some
corruption in the font files in question.
