DoomyMuffins Posted November 22, 2009 Share Posted November 22, 2009 After downloading the most recent update, images with no background color automatically change to a white background. I really liked that transparent feature. Is there anyway to adjust the settings so it goes back to the way it was? Quote Link to comment Share on other sites More sharing options...
Myrddin Posted November 22, 2009 Share Posted November 22, 2009 Hello DoomyMuffins. When speaking of 'images with no background color automatically chang[ing] to a white background', are you referring to when saving the image? If so, try saving in a format that can handle transparency, such as 32-Bit PNG. Does this work for you? Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
DoomyMuffins Posted November 22, 2009 Author Share Posted November 22, 2009 Yes! Thank you! Quote Link to comment Share on other sites More sharing options...
Myrddin Posted November 22, 2009 Share Posted November 22, 2009 No problem. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
