Lero Posted November 21, 2009 Share Posted November 21, 2009 I just recently downloaded paint.net. Everytime I add a new layer, the background picture becomes that current layer. What are the actual steps for adding layers? Maybe I left a step out. Thanks Quote Link to comment Share on other sites More sharing options...
Crimson Posted November 21, 2009 Share Posted November 21, 2009 It is possible that you are duplicating the current layer instead of adding a new one. To add a new layer: [*:1456j3n6]Press Ctrl + Shift + N[*:1456j3n6]Go to Layers > Add New Layer[*:1456j3n6]Press the :AddNewLayer: button in the Layers window (you might be pressing the :DuplicateLayer: button which duplicates the layer instead of adding a new one) Hope this has helped. Edited for clarity. Quote Create A Professional-Looking Product Advertisment Mockup flickr | Deviant Art Link to comment Share on other sites More sharing options...
Lero Posted November 21, 2009 Author Share Posted November 21, 2009 First, I select a background. Then when I click ctrl + shift + n, a checkered box appears in the layers window labeled as layer 2. My original picture is listed in the box as background. If I then try to open a recent file as the new layer file, The new file is then listed as the background, and the first background dissapears. Is this making sense? Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted November 21, 2009 Share Posted November 21, 2009 Click Layers -> Import from file. Quote Link to comment Share on other sites More sharing options...
Lero Posted November 21, 2009 Author Share Posted November 21, 2009 Thank you! Quote Link to comment Share on other sites More sharing options...
