Dragoneer Posted November 16, 2009 Share Posted November 16, 2009 The problem with the Magic Wand is that it rarely if ever surrounds the image without spreading into the other part of the picture. I would like to be able to border off odd shaped images from the rest of the background or other surrounding things on a particular picture like the Magic Wand is supposed to. I assume there is a plug-in that is more effective that will address my problem. I tried searching for a plug-in but couldn't find one. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 16, 2009 Share Posted November 16, 2009 Have you adjusted the tollerance of the magic wand? I find that a tollerance of 31 usually works really well. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Neil Cassidy Posted November 17, 2009 Share Posted November 17, 2009 Yeah I tend to adjust Magic Wand to 35% tolerance when I'm trying to pick out a certain region. Segment Image might be able to help you with this as well, link is below. I suggest starting with a moderate number of regions (around 10-20) and setting the bias to 0.75. You'll want to copy the image onto a new layer before running the plug-in, make the selections there, and then toggle the visibility of the segmented layer to see how well it's fitting. Use Magic Wand at tolerance 0% to select the segmented regions, hold Ctrl while clicking to select multiple regions together. Quote Segment Image : Average Color (HSL) : Eigen Blur : []Cool, new forum! Link to comment Share on other sites More sharing options...
