whisprer Posted November 16, 2009 Share Posted November 16, 2009 I'd like to make the edges of a photo fade. There used to be a tutorial on here for this a couple versions back that involved layers and gradients, but I can't find the tut or the plug-in (it showed up under effects and allowed you to change the alpha from 100 to 0). Any help on how to do this or where to find plug-ins/ tutorials would be helpful. This is what I was able to do with gradient blur.... Quote Link to comment Share on other sites More sharing options...
LJXD Posted November 16, 2009 Share Posted November 16, 2009 A quick method is making your primary colour transarent and your secondary colour black (or white). Then go to Gradient and choose radial (the circular one). Click the centre of your photo and drag to the edge. Hope this answers your question Quote |My Sig Tut| Deviant Art |Advanced Grunge Texture|My Gallery The Birthplace of Life Link to comment Share on other sites More sharing options...
Sozo Posted November 16, 2009 Share Posted November 16, 2009 Or use the vingette plugin. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 16, 2009 Share Posted November 16, 2009 The vignette effect is part of Ed Harvey's plugin pack, which you can find here: viewtopic.php?f=16&t=26244&start=0 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
whisprer Posted November 19, 2009 Author Share Posted November 19, 2009 I have the vingette plug-in, however, I don't like the black... and I'd like to do a more even job around rectangular photos. Does anyone remember the old duplicate layer way... I can no long find the tut, but I really liked the results from that method. BTW, thanks for all the responses! Quote Link to comment Share on other sites More sharing options...
