unit scale
Could someone please help. I have opened a pdf file into paintnet. I want to elongate a rectangle to a certain dimension. Current dimension of rectangle is 1.2 cm. When I print this out, it measures exactly to the right dimensions (1.2 cm.) Problem now is... when I use the unit measurement scale (in cm.) it shows the object at 1.5 cm. If I now select and drag the rectangle to the dimensions I want (6 cm.) I come out short in length (4.7 cm). Any suggestions why I am having difficulty with the unit scale being out? Hope this question is detailed enough to understand. Thanks for anyone who will take the time to help me out.
1. Are you sure you're opening a pdf? :D
2. This plugin might help: Printer+
