Beta Posted November 9, 2009 Share Posted November 9, 2009 After I hit continue in the admin prompt in vista I get this; http://img682.imageshack.us/img682/349/pdnerr.jpg After I hit Ok PdN 3.36 opens.. ------- Apparently I had done what Rick told me to do wrong, problem fixed anyway... Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 9, 2009 Share Posted November 9, 2009 You probably have removed .NET 3.0 somehow (yes, 3.0, not 3.5). Download and installed this, http://www.microsoft.com/downloads/deta ... da479ab0d7 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Beta Posted November 10, 2009 Author Share Posted November 10, 2009 Okay, I have edited the first post to include more details. I have tried just about everything to fix my problem. WRN: Assembly binding logging is turn OFF. To enable assembly biind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Notw: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. Does this mean I need to edit Fusion!EnableLog or create Fusion!EnableLog? I tried editing it but I only found EnableLog, and I found Fusion. But I never found Fusion!EnableLog. Quote Link to comment Share on other sites More sharing options...
