piesaretasty Posted November 2, 2009 Share Posted November 2, 2009 How would you do a water effect? Like a whirlpool/wave. Quote Link to comment Share on other sites More sharing options...
Sozo Posted November 2, 2009 Share Posted November 2, 2009 First I point you towards the rules. You are violating number six, so please change your title. Regarding your question, do the Twist or Wave effects not produce the desired result? (I'm pretty sure twist is included in Paint.NET now) Quote Link to comment Share on other sites More sharing options...
piesaretasty Posted November 2, 2009 Author Share Posted November 2, 2009 Should've worded differently. Not like a whirlpool, scratch that. Like a water droplet effect. Quote Link to comment Share on other sites More sharing options...
Sozo Posted November 2, 2009 Share Posted November 2, 2009 There are ripple and drop ripple effects here. Check our search engine out. Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted November 2, 2009 Share Posted November 2, 2009 (I'm pretty sure twist is included in Paint.NET now) Correct. Quote Link to comment Share on other sites More sharing options...
