Sakana Oji Posted January 5, 2019 Share Posted January 5, 2019 On 12/9/2006 at 5:44 AM, BoltBait said: I have created an effect that will do them all for you! Download it here: http://paintdotnet.12.forumer.com/viewtopic.php?t=4085 PAGE NOT FOUND Quote Big McThankies From McSpankies! Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 5, 2019 Share Posted January 5, 2019 11 minutes ago, Sakana Oji said: PAGE NOT FOUND In the future, please use archive.org to find the corresponding topics for old forum links. In this case, the topic you're looking for is: https://forums.getpaint.net/topic/3474-ink-sketch-effect-plugin-now-with-source-code/ This is also the third time this week you have not followed the forum rules. On two separate occasions, Pixey and I both asked you to read and follow them. There are reasons behind every one of those rules. You need to follow them. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
dipstick Posted January 5, 2019 Share Posted January 5, 2019 You may also want to try out the G'mic plugin. It has a cartoon filter among many others.. Quote Link to comment Share on other sites More sharing options...
Sakana Oji Posted January 6, 2019 Share Posted January 6, 2019 15 hours ago, toe_head2001 said: This is also the third time this week you have not followed the forum rules. Oh my goodness me, I'm so sorry! Quote Big McThankies From McSpankies! Link to comment Share on other sites More sharing options...
Nagato1228 Posted May 21, 2020 Share Posted May 21, 2020 I've been doing abstract art with Paint.net for around five years, and in that time I've found many different styles that I would cling to for a while. About four years ago I started using Ownage's Toon filter plugin posted in 2006 (https://forums.getpaint.net/topic/1671-toon-filter/), and I liked it mainly because of a method I found on the forums to create a nice cracked-surface effect. I'm not sure when exactly, but at some point a few years ago, the Toon filter disappeared from my effects list. I initially hadn't tried much except for making sure the .dll was still in my effects folder, which it was. I recently tried again by just re-downloading the plugin, but still no luck. It wasn't until tonight that I really sat down and tried to figure it out. I opened the .dll using 7Zip, and compared the files with those of effects I knew still worked, and still wasn't able to make it available. I'll now concede that I lack the knowledge required to fix it. So I scoured the forums trying to see if anyone else has had a similar issue, and when that didn't pan out, checked to see if Ownage might be available to ask about it. Seeing that they haven't visited since 2006, I decided to set up an account here (take a look through the forum rules so I don't mess this post up) and ask all you fine folk if you've experienced something like this, and if so, your possible solutions. I've included the first piece I made using the effect (resized to fit forum requirements). Quote Link to comment Share on other sites More sharing options...
null54 Posted May 21, 2020 Share Posted May 21, 2020 It is not showing up for me either, and it is not appearing in plugin errors. I will try rebuilding it from the source code, the DLL may be incompatible with the latest versions of Paint.NET. Also, this should have been posted in the plugin thread. Perhaps one of the mods will move it there for you. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted May 21, 2020 Share Posted May 21, 2020 I recompiled the effect from the source code in the first post. Changes: Moved it into the Artistic submenu Added a Plugin Browser preview image (I cropped the example image in the first post) 46 minutes ago, welshblue said: I always thought it was under Artistic but this one is at the bottom (of Mine) Effects tab I was going to move it into Stylize, but Artistic is a better fit. TOON.zip Source code: Spoiler // Name: TOON // Submenu: Artistic // Author: ownage // Title: // Version: 1.0 // Desc: // Keywords: // URL: https://forums.getpaint.net/topic/1671-toon-filter/ // Help: // filter kernel const int size = 5; // odd number //play around with the matrix for interesting effects. int[,] conv = new int[size, size] { {-1, -1, -1, -1, -1}, {-1, -1, -1, -1, -1}, {-1, -1, 30, -1, -1}, {-1, -1, -1, -1, -1}, {-1, -1, -5, -1, -1}, }; unsafe void Render(Surface dst, Surface src, Rectangle rect) { int radius = (size-1)/2; for(int y = rect.Top; y < rect.Bottom; y++) { int top = y - radius, bottom = y + radius; if (top < 0) top = 0; if (bottom >= dst.Height) bottom = dst.Height - 1; for (int x = rect.Left; x < rect.Right; x++) { int left = x - radius, right = x + radius; int c = 0, s = 0, r = 0, g = 0, b = 0; if (left < 0) left = 0; if (right >= dst.Width) right = dst.Width - 1; for (int v = top; v <= bottom; v++) { ColorBgra *pRow = src.GetRowAddressUnchecked(v); int j = v - y + radius; for (int u = left; u <= right; u++) { int i = u - x + radius; int w = conv[i, j]; ColorBgra *pRef = pRow + u; r += pRef->R * w; g += pRef->G * w; b += pRef->B * w; s += w; c++; } } dst[x, y] = ColorBgra.FromBgr( Int32Util.ClampToByte(b), Int32Util.ClampToByte(g), Int32Util.ClampToByte(r)); } } } 1 4 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 21, 2020 Share Posted May 21, 2020 13 hours ago, welshblue said: Is this the one ? I always thought it was under Artistic but this one is at the bottom (of Mine) Effects tab That's the one I have/had. @null54 Thanks for updating the filter. I'll replace the file in the first post, unless you want to create a new thread? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
null54 Posted May 22, 2020 Share Posted May 22, 2020 1 hour ago, Ego Eram Reputo said: ...unless you want to create a new thread? I do not think that there is any point in creating a new thread. I did not make any changes to the plugin's algorithm. I only changed the menu category and added a Plugin Browser preview image. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Panchdara Posted May 22, 2020 Share Posted May 22, 2020 (edited) On 5/21/2020 at 12:28 PM, null54 said: I recompiled the effect from the source code in the first post. Changes: Moved it into the Artistic submenu YES Added a Plugin Browser preview image (I cropped the example image in the first post) ???????????? Reveal hidden contents // Name: TOON // Submenu: Artistic // Author: ownage // Title: // Version: 1.0 // Desc: // Keywords: // URL: https://forums.getpaint.net/topic/1671-toon-filter/ // Help: // filter kernel const int size = 5; // odd number //play around with the matrix for interesting effects. int[,] conv = new int[size, size] { {-1, -1, -1, -1, -1}, {-1, -1, -1, -1, -1}, {-1, -1, 30, -1, -1}, {-1, -1, -1, -1, -1}, {-1, -1, -5, -1, -1}, }; unsafe void Render(Surface dst, Surface src, Rectangle rect) { int radius = (size-1)/2; for(int y = rect.Top; y < rect.Bottom; y++) { int top = y - radius, bottom = y + radius; if (top < 0) top = 0; if (bottom >= dst.Height) bottom = dst.Height - 1; for (int x = rect.Left; x < rect.Right; x++) { int left = x - radius, right = x + radius; int c = 0, s = 0, r = 0, g = 0, b = 0; if (left < 0) left = 0; if (right >= dst.Width) right = dst.Width - 1; for (int v = top; v <= bottom; v++) { ColorBgra *pRow = src.GetRowAddressUnchecked(v); int j = v - y + radius; for (int u = left; u <= right; u++) { int i = u - x + radius; int w = conv[i, j]; ColorBgra *pRef = pRow + u; r += pRef->R * w; g += pRef->G * w; b += pRef->B * w; s += w; c++; } } dst[x, y] = ColorBgra.FromBgr( Int32Util.ClampToByte(b), Int32Util.ClampToByte(g), Int32Util.ClampToByte(r)); } } } Edited May 22, 2020 by Panchdara Added jpg Quote Link to comment Share on other sites More sharing options...
null54 Posted May 22, 2020 Share Posted May 22, 2020 7 hours ago, Panchdara said: Added a Plugin Browser preview image (I cropped the example image in the first post) ???????????? It looks like CodeLab is not embedding the preview image into the DLL, it also does not add it to the generated VS project. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
toe_head2001 Posted May 22, 2020 Share Posted May 22, 2020 2 minutes ago, null54 said: It looks like CodeLab is not embedding the preview image into the DLL, it also does not add it to the generated VS project. I just looked at that code the other day, and know exactly where the bug is. Fixing... Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 23, 2020 Share Posted May 23, 2020 Add DLL to first post. I've cunningly hidden it behind a large blue download button. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
