aaronhoffman Posted October 25, 2009 Share Posted October 25, 2009 If the Shift Key + "Move Selected Pixels" combo is used (to maintain aspect ratio during resize) after the "Move Selection" tool is used to change the aspect ratio of the selection - the aspect ratio from before the "Move Selection" is used, and not the current aspect ratio. Steps to recreate: 1. Use "Rectangle Select" to select a area 2. Use "Move Selection" to change the aspect ratio of the selection 3. use Shift + "Move Selected Pixels" - current aspect ratio will not be maintained Video: http://www.screentoaster.com/watch/stV0xUQ0xIR1xZRFRVU1lRUVRQ/paint_net_bug_move_selected_pixels_after_move_selection Quote Link to comment Share on other sites More sharing options...
yellowman Posted October 25, 2009 Share Posted October 25, 2009 Yes that's right, click cut and then past (both are available in the menu toolbar) on same layer, this will keep the new aspect ratio. I don't know if it is a bug as you mentioned, but I like this feature of keeping the original. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
Wilson Posted October 26, 2009 Share Posted October 26, 2009 Yeah, I've never really understood why this happened either but what Yellowman said should sort it. Quote Link to comment Share on other sites More sharing options...
