Curmudgeon 1 Posted January 12, 2010 Share Posted January 12, 2010 3. :AddNewLayer: Make a new layer. Using the magic wand in global mode, click on your text to get it selected. :ShapeInterior: Using the ellipse tool (use filled shape mode), draw a white highlight on the top of your text. :Properties: Double click on your layer to open layer properties, then change the opacity to 45 (or whatever you prefer) 4. Temporarily make your background layer invisible (so you can see how thick the outline is). Go to Effects>Outline Object. Outline your text in white. I chose a radius of 7 and strength of 5. :DuplicateLayer: Now, duplicate the text layer. :Curves: Go to Adjustments>Curves. Make sure you have selected the bottom duplicate layer. With R,G, and B checked, and in RGB mode, drag the point to the bottom right of the box. Your text should now be black (the text will get black around the edges). :GaussianBlur: Now, go to Effects>Blurs>Gaussian Blur and blur by 10px (or whatever you prefer). Your image should look something like this: Relative newbie to Paint.net, so hope someone can help me - apologies if I'm being really stupid too. I can manage fine with this tut up the first point above. Following the tutorial to the letter, it says to create a new layer, and then use the magic wand in global mode to select the text. When I do this, it selects the whole layer rather than just the text. Should I reselect the text layer before doing this? (presumably by highlighting that layer in the layers box). Presumably the next stage of drawing the ellipse should be on the new layer I created? When I try step 4, even if selecting the text via reselecting layers above, I use the outline tool, but get no result - it just remains with the thin black outline of the magic wand selection. Hope someone can help me...as its sending me round the bend not being able to do something which should no doubt be so simple. Hopefully I'm just selecting the wrong layers at the wrong time or something, so if someone could even highlight the layers I should be selecting for each task, that should hopefully help.... Know this forum isn't for questions, but thought better asking here, just in case anyone else is having the same issues....(no doubt will just be me!) Thanks guys.... Yes, step 3 would've been better served by saying: use magic wand in global mode on text layercreate new layerdraw ellipse in filled shape modego to layer properties since it's presently asking you to create a new layer, then go back to the text layer and selecting the text, then back to the new layer and yes, this is the correct forum to ask questions, when the question deals with a specific tutorial, ask it in the tutorial's thread. Quote Link to post Share on other sites
Commadant J. 0 Posted January 19, 2010 Share Posted January 19, 2010 Thats my result. Gonna make a bigger one now. Hidden Content: Quote Link to post Share on other sites
Jboneck158 0 Posted January 19, 2010 Share Posted January 19, 2010 Here's My Try Quote | My LDS Planet||My Gallery| Link to post Share on other sites
Leoholbel 0 Posted January 25, 2010 Share Posted January 25, 2010 Nice tut, thanks! Doesn't it look like ? Quote Link to post Share on other sites
outofcontrolchild 0 Posted January 30, 2010 Share Posted January 30, 2010 Sweet stuff! He's something I made using this tut. It's a banner for some site I'm on. Quote Link to post Share on other sites
AdamCG 0 Posted February 3, 2010 Share Posted February 3, 2010 LOL! looks like a better version of twitter logo!!! nice tut, thx Quote Link to post Share on other sites
ClockworkDemon 0 Posted June 29, 2010 Share Posted June 29, 2010 I LOVE IT!!!! Thanks for the tutorial dude... This is what I came up with: Quote Link to post Share on other sites
Connor822 0 Posted July 12, 2010 Share Posted July 12, 2010 Thanks Quote Link to post Share on other sites
Gazek 0 Posted August 23, 2010 Share Posted August 23, 2010 This tut rulz. I'm awe strucken. This is great, there's no end to my applause... This is what I made: Yeah, it's a book's title. Great job once again. Quote Serious graphics up in that post. Link to post Share on other sites
nestoflo 0 Posted September 23, 2010 Share Posted September 23, 2010 Love the tutorial changed some things and this is what I got!!! Quote Link to post Share on other sites
D3T0N4T0R 0 Posted September 24, 2010 Share Posted September 24, 2010 Nice tutorial. I found it really easy to follow. I would post my outcome, but PDN didn't save the file properly, so I can't open/upload it. Quote Sometimes I think the world would be much better without so much technology. ~ Sent from my iPhone. TEAIM - Problem solved! Link to post Share on other sites
mattz1996 0 Posted September 25, 2010 Share Posted September 25, 2010 Here's my result: Cheers:) Quote  Click my signature to register for the game my signature is based off of If you get to level 5, it helps me too! Link to post Share on other sites
Kirbydlx 0 Posted September 30, 2010 Share Posted September 30, 2010 This tutorial will show you how to make glossy, "web 2.0 style" text. <snipped by EER - no need to quote the whole tutorial > Please post any questions about this tutorial, results, and advice in this topic. Thanks! Quote Link to post Share on other sites
bananaxdumpling 0 Posted October 5, 2010 Share Posted October 5, 2010 ohhh goody, my first post. hehe. here's my result. um... for some reason... the step where to change it's color with Brightness/Contrast or using ColorBalance... i used balance color while on the "text" plate, and then when trying to gradient it from bottom to top, it wouldn't come out for me... and instead i gradient from bottom to top in the "text gradient" plate instead. hence, the different colors on mine and i think it's because i played with the color balance of it. oh well, i had loads of fun, and glad that i can now mess with text and do something different instead of the same old thing. Quote Link to post Share on other sites
Player1244 0 Posted October 8, 2010 Share Posted October 8, 2010 Hi, this is my first forum post and this is what I made: I know, it's HUGE! But I was too lazy to scale it xD Quote Link to post Share on other sites
5p4rk13r 0 Posted October 31, 2010 Share Posted October 31, 2010 Nice tut Here's my result: Snogry, what font is this? I really would like to have it. Thanks. Quote Link to post Share on other sites
kmplsv 0 Posted October 31, 2010 Share Posted October 31, 2010 Bah, looks like the links to download the plugins from the original post are dead. CyberSpace (or anyone else with the original files), would you be so kind as to re-upload the files and fix the links? This looks like a great plugin and I'd love to check it out. Thanks! Quote Link to post Share on other sites
pyrochild 363 Posted October 31, 2010 Share Posted October 31, 2010 Bah, looks like the links to download the plugins from the original post are dead. CyberSpace (or anyone else with the original files), would you be so kind as to re-upload the files and fix the links? This looks like a great plugin and I'd love to check it out. Thanks! You can find all the necessary plugins by searching or in the plugin index Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
Ego Eram Reputo 2,835 Posted October 31, 2010 Share Posted October 31, 2010 In the interests of not having the above conversation repeated ad nauseum, I've updated the links to the plugins in the first post. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Tibfib 0 Posted December 11, 2010 Share Posted December 11, 2010 This is exactly the tutorial I was looking for. Thanks a ton! Quote Link to post Share on other sites
USERNAME1107 0 Posted April 20, 2011 Share Posted April 20, 2011 great tutorial make more here is what i got Quote Link to post Share on other sites
doogiski 0 Posted April 28, 2011 Share Posted April 28, 2011 (edited) Great tutorial, here is what my final looks like. Thanks again! Edited April 28, 2011 by doogiski Quote Link to post Share on other sites
adel 2 Posted June 8, 2011 Share Posted June 8, 2011 Thak u for this effect; it's nice and this is my try Quote Link to post Share on other sites
Darthpyro 0 Posted June 12, 2011 Share Posted June 12, 2011 After 20 minutes, I have given up on trying to get the Gradient in step 2 to work. Quote Link to post Share on other sites
Ego Eram Reputo 2,835 Posted June 13, 2011 Share Posted June 13, 2011 The gradient in this tutorial is used to blend the two layers together seamlessly. In that respect, this tutorial might be worth reading as it explains the same process (in that case blending two images, but the concept is the same): http://forums.getpaint.net/index.php?/topic/19517-beginner-image-merging-image-heavy/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
