Shiseiji Posted October 22, 2009 Share Posted October 22, 2009 Hi, been using Paint for a year plus, and diligently look at [Help] and search the board for answers before I ask. I have four layers, one is selected (meaning it is in the blue row) and checked with the check mark. When I crop the selected and single checked layer, all four layers are cropped. I know I must be missing something, but can't figure it out. TIA, Ron Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted October 22, 2009 Share Posted October 22, 2009 If you want to make the rest of the layer transparent, invert the layer's contents and press delete. If you want to crop the layer to a specific size, then unfortunately Paint.NET doesn't support layers of different sizes. Quote Link to comment Share on other sites More sharing options...
Shiseiji Posted October 22, 2009 Author Share Posted October 22, 2009 Thanks much! then unfortunately Paint.NET doesn't support layers of different sizes, won't do what I thought it would do. I will revert to resizing the image in PowerPoint (familiarity plus can save the image in multiple formats including png) and then opening it or pasting it into a layer. Appreciate the help and kindness to a beginner, Ron Quote Link to comment Share on other sites More sharing options...
Frontcannon Posted October 22, 2009 Share Posted October 22, 2009 You can just select the whole layer and then crop it, I think this will just affect the layer you're working with,as far as I know. Quote Night Vision Text Effect Tutorial Gallery reddit.com/r/futurebeats | My Mixcloud Link to comment Share on other sites More sharing options...
Simon Brown Posted October 22, 2009 Share Posted October 22, 2009 To clarify what I said, it doesn't support layers of different sizes, but you can make only part of the layer opaque. Quote Link to comment Share on other sites More sharing options...
fastforward Posted October 28, 2009 Share Posted October 28, 2009 Hello. I do not know where to ask this but I read about layers and so I am asking. I am new for the Paint.NET. May I know that what the layers mean in the picture. Is different pictures have different no of layers or same. Can I remove ballpen marking from photo ? Or tell me about the exact forum where i can ask this question ? Quote when thre is a will there is a way. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 28, 2009 Share Posted October 28, 2009 To find out about layers: http://www.getpaint.net/search.html + layers :wink: Removing ballpoint pen - try this: How to "Erase" Pencil Marks! Or you could try asking this in the General Discussion & Questions section. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
