cattails Posted October 17, 2009 Share Posted October 17, 2009 Will plugins I download now function in all new versions of PDN coming in the future? Or will I have to download new versions of the plugins as well? Thanks Quote Link to comment Share on other sites More sharing options...
Frontcannon Posted October 17, 2009 Share Posted October 17, 2009 Of course you'll have to download the updated versions of these plugins. Quote Night Vision Text Effect Tutorial Gallery reddit.com/r/futurebeats | My Mixcloud Link to comment Share on other sites More sharing options...
cattails Posted October 17, 2009 Author Share Posted October 17, 2009 Of course you'll have to download the updated versions of these plugins. So that means plugins I use now will have to be removed (deleted) and replaced with their newer versions? How do I find out where the new versions of plugins will be located to download? Thanks. Quote Link to comment Share on other sites More sharing options...
oma Posted October 17, 2009 Share Posted October 17, 2009 depends on each plugin. I've tried some of them out in the beta and they work fine. generally after Rick has put up his finalized version of the new paint.net (not alpha version or beta version) the plugin writers make their changes if required. So you may not need to delete any it all depends on which ones work after the internal paint.net changes are finished. ciao OMA Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 18, 2009 Share Posted October 18, 2009 So that means plugins I use now will have to be removed (deleted) and replaced with their newer versions? How do I find out where the new versions of plugins will be located to download? Thanks. Plugins that are giving a new version of PDN trouble will be reported in the "Utilities" menu (v3.5 beta 1 and later). You won't have to worry about anything that is not mentioned there. Generally authors will update their plugins to work with the new public release of PDN and post the updates or links to those updates in the same thread that the original plugin was released. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
