Help Select a car?
Perhaps you can try using the Line/Curves tool to make an outline of the car on a new layer than select inside the outline and go back to the layer of the car.
You can use the Lasso Select tool, but that would be too shaky and complicated.
---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----
D                  E                  S                  T                  I                 N                  Y
