Problems installing Paint.net
Hello, I am having troubles trying to install this excellent program; I will show you the error message:
I have looked into it somewhat but perhaps another solution is alluding me. I DO have .NET Framework 3.5 SP1 installed and I have even repaired it, but I still get the same result.
Any help would be greatly appreciated, thanks.
Any additional info that you can provide may be helpful.
What OS? Vista, XP, etc.?
First time installation on this system or re-install?
Do you have a D:Paint.NETStaging folder, and is the filename/number the same
as what is on the error message?
This link may or may not apply in your case.
Don't know whether you have seen this yet.
If you can post back specifying what steps you have already tried, it may
speed things along.
Edited by Sarkut
