help with a project
kungfugi
I have a small art project I'm doing right now, not for school, just because I'm bored. But i have a picture and i want to change it to black/white/gray. But i also need the picture to break up into those colors with as big of sections as possible but still make it look like the original picture.
I'm not sure if that makes much sense, but if anyone could help it would be much appreciated
what I'd suggest doing:
  • run the "grayscale on colored paper" plugin with the color set to white (255,255,255)
    then use posterize and reduce the colors to the number you want total
this usually gives you a better grayscale than a simple black & white would produce
and posterize is the way to reduce the number of shades of gray you want
11001_58c7824efc5bb46257f415c29fb6693d
11001_c3d8e6f1d42b404d8b5aca261dd85bb5
11001_76b39d37ce7f1ffff8c473297622ca6c
thanks Curmudgeon that works almost exactly what i wanted. I'm going to try a few other effects with it. But if i can't get any better then this will work just fine
