immewnity Posted October 4, 2009 Share Posted October 4, 2009 As evidenced here, it is possible in many apps to do this. Supposedly GIMP, Jasc/Corel PaintShop Pro, and Photoshop support the feature. Why doesn't PDN support this? It would be of great help. Quote from page: if you punctually need a font, you don't need to install it. Just double-click on the .ttf file, and while the preview window is opened you can use it in most of the programs you'll launch (apart from a few exceptions like OpenOffice). Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 4, 2009 Share Posted October 4, 2009 Try installing the beta release of Paint.NET v3.5. If it doesn't work there, then oh well. I've never heard of being able to do this. I won't add extra code to make it work, either; it's an ultra corner case. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
