txsteve Posted September 25, 2009 Share Posted September 25, 2009 Let's say I have a face on a white background... I can select the white background around the face and hit delete. Save as Png format. Open a new image to use as a background then pull in the face.png file and the edge looks horrible. What do you do to clean up the edge or is there a better way to not have such a jagged image? Quote Link to comment Share on other sites More sharing options...
APShredder Posted September 25, 2009 Share Posted September 25, 2009 Try putting the face on a seperate layer and then using the Feather plugin. EDIT: Also, next time, try using alpha masking. Here's a tutorial about it. http://paintdotnet.forumer.com/viewtopic.php?f=37&t=28050 Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Urnemanden Posted September 25, 2009 Share Posted September 25, 2009 Here is an example of the result you get after feathering your object: Before using Boltbaits feather plugin: After using Boltbaits feather plugin: Quote About - Website Link to comment Share on other sites More sharing options...
txsteve Posted September 25, 2009 Author Share Posted September 25, 2009 Those are great ideas. Thank you. Quote Link to comment Share on other sites More sharing options...
