Gradient Control w/ Top + Bottom Colors?
APShredder
Ok, well I almost got copying the code to work, except I'm still getting a error message. I've tried everything I can think of (which isn't all that much) to get rid of it, but it won't go away. :?
Error Message: 'ExtractColor.GradientControl.Dispose(bool)': no suitable method found to override
And of course here's the code that's causing the error.
namespace ExtractColor
   partial class GradientControl
       /// Required designer variable.
       private System.ComponentModel.IContainer components = null;
       /// Clean up any resources being used.
       /// true if managed resources should be disposed; otherwise, false.
       protected override void Dispose(bool disposing)
           if (disposing && (components != null))
               components.Dispose();
           base.Dispose(disposing);
       #region Component Designer generated code
       /// Required method for Designer support - do not modify
       /// the contents of this method with the code editor.
       private void InitializeComponent()
           components = new System.ComponentModel.Container();
           this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
       #endregion
Ok well I tried doing that, but all I got was a new error message.
'ExtractColor.GradientControl' does not implement interface member 'System.IDisposable.Dispose()'
I get that along with the other message I was getting before.
using System;
   partial class GradientControl : [b]IDisposable[/b]
       #endregion
Try replacing the dispose method with:
           protected virtual void Dispose(bool disposing)
               this.Dispose(disposing);
           public void Dispose()
               Dispose(true);
Just to be clear, replace the current code with:
    using System;
                   Dispose(true);
           #endregion
'ExtractColor.GradientControl' does not contain a definition for 'AutoScaleMode' and no extension method 'AutoScaleMode' accepting a first argument of type 'ExtractColor.GradientControl' could be found (are you missing a using directive or an assembly reference?)
The name 'PixelOffsetMode' does not exist in the current context
The type or namespace name 'InvalidEnumArgumentException' could not be found (are you missing a using directive or an assembly reference?)
There's a bunch of those.
The type or namespace name 'LinearGradientBrush' could not be found (are you missing a using directive or an assembly reference?)
The name 'SmoothingMode' does not exist in the current context
Cannot implicitly convert type 'PaintDotNet.ColorGradientControl' to 'ColorGradientControl'
There's a bunch of those too.
These are pretty much all the errors and there are some warning messages too, which I can post if you want to see them.
I think you need to learn more of the basics of C# and programming in general... Simon is not your personal tutor/debugger.
ambigram signature by Kemaru
[i write plugins and stuff]
As much as I hate to admit it, you're probably right. I've been trying to figure out something more then just the basics, but I can't find anything that really helps me. I've tried reading source codes from different plugins, I've tried finding online tutorials, but nothing every really helps. So, maybe it's better if I step away from programming for right now. Or on second thought maybe you could tell me somewhere where I can learning more than the basics. I'd really appreciate it.
No no no, I don't mean to discourage you from programming. I'm just trying to say, start with a foundation instead of trying to start with the electricity and plumbing. Have you looked at BoltBait's CodeLab tutorials? Google is also a very good resource for either tutorials or looking up any error messages you get.
Yeah, I get what you're saying. After reading your post, I decided I was high time I actually learn programming from someone other than myself. You see, everything I know so far, I taught myself. I never had any kind of tutoring from anyone other than a few online tuts. So I googled a few C# websites, and I'm starting my programming education over. So I have to say thank you pyrochild, for helping me realize that I needed to learn the basics before I could do anything too advanced.
I better see some awesome plugins coming from you soon :P
Also, don't be afraid to ask for help on this forum -- that's what it's for, after all. Just try not to turn it into "write my plugin for me." ;)
Don't worry I plan to. :wink:
Don't worry about that either. I'll probably still have a bunch of questions along the way though.
don't get discouraged. I've been reading and re reading C+ book for over a year. just starting to get the idea of what's what. I haven't even tried to do a plugin yet. you are way ahead of me.
keep at it. go slow, try not to get discouraged.
ciao OMA
Thanks for the wise words of encouragement oma. :)
