SithLord Posted September 22, 2009 Share Posted September 22, 2009 hi guys. i have a question. i don't know if it's been asked before. i'd appreciate all help. thanks. my question is how can i do this with paint.net? Quote Link to comment Share on other sites More sharing options...
Kraze. Posted October 2, 2009 Share Posted October 2, 2009 Urmm... im not sure if you could do that, Maybe try cutting out some of the object then pasting it to a new layer then add a drop shadow. You may need the drop shadow plugin. and then change the opacity maybee? Hope this helpss Quote Link to comment Share on other sites More sharing options...
Axle Posted October 3, 2009 Share Posted October 3, 2009 i've been trying to do this for ages and when i work it out i'll post a tut. >>off topic>> @Kraze.: it's cool the way your sig looks as if it is part of the forum background and is a cutout Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
Rubrica Posted October 3, 2009 Share Posted October 3, 2009 I wonder... viewtopic.php?f=16&t=22521 Try the plugin called displacement... I can't offer results, I'm afraid. But with practice, I think this could work... Quote Link to comment Share on other sites More sharing options...
Kemaru Posted October 3, 2009 Share Posted October 3, 2009 What I would do: Paste the stock image of shattered glass on a new layer above the guy. Adjust the contrast and colours so it's black and white and it's low on detail. Set the blend mode of that layer to darken, multiply or overlay. Flatten the image, select all and copy, then undo until you have the layers again. Open a new layer, paste into it the flattened image. Now take the clone stamp and choose a part you want to "lift". ctrl+click a part on the layer with the image and start cloning on a new layer. That's the basic structure I'd use, if you work on it for a while I'm sure you'll get a professional looking effect. Quote Hatred does not cease by hatred, but only by love; this is the eternal rule. |fb(page)|portfolio|blog| Link to comment Share on other sites More sharing options...
SithLord Posted October 7, 2009 Author Share Posted October 7, 2009 thanks for the reply guys. i will try your suggestions and come back here to give you an update. thanks! Quote Link to comment Share on other sites More sharing options...
