How to whiten teeth using pdn (very simple and fun)
person_321
This tut will show you how to make your teeth whiter using paint.net
you will need color tint
you will also need some selecting knowledge.
so let's start out by getting us some yellow teeth
:shock: that's some ugly teeth
so start out by opening your picture and duplicating the layer.
next we need to select the teeth. for this one, I had to use lasso select
I didn't do a very good job on it, but it will still turn out okay.(Just a little yellow on the sides :lol::lol::lol::lol: )
so on the duplicated layer, run color tint at default settings
now it looks worse then before! It now looks freakishly white!
so I'm going to adjust the opacity of the layer
and we're done! please comment and share your pictures
Tutorial Rules state that your images should be less than 800px at their largest dimension (check them out, yellow box at the top of this page). Please re size your images appropriately.
What is the point of the second image?
Please, This is very easy and can be done by just fiddling with effects.
Read the rules, and the tutorial rules.
You are not a moderator.
