Boarder Help For Sigs
Try using the rounded rectangle tool to make the outline border of the signature. Then erase the parts outside of the border you don't want and use a drop shadow effect.
You can find the drop shadow plug-in on this forum.
---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----
D                  E                  S                  T                  I                 N                  Y
Better yet, use the Rounded Rectangle plug in set to black. Make your main background color white, flatten layers, save it as a mask, and then run alpha mask over the sig you want to make. Then use Selection>Outline, and then Drop Shadow.
Experimenting with PDN is the key! :idea:
Officially retired from this forum. Have a nice day.
