Dark Thoughts Posted September 12, 2009 Share Posted September 12, 2009 Is it possible to merge two PDN projects so that if one project has (for example) 8 layers and the other has 20 layers, the new project would show all 28 layers? Quote Link to comment Share on other sites More sharing options...
APShredder Posted September 12, 2009 Share Posted September 12, 2009 Yeah that's easy. First open one of the pictures you want to merge. Then go to Layers --> Import From File, and select your second picture. Now all the layers from both pictures should be there. Hope this helps. :wink: Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Dark Thoughts Posted September 12, 2009 Author Share Posted September 12, 2009 Thanks for the fast reply! I was just coming back to post that I found that you can drag n' drop one PDN project into another. Quote Link to comment Share on other sites More sharing options...
