petters Posted September 9, 2009 Author Posted September 9, 2009 Hi, in Microsoft Pictur IT it was functionality to make a picture more or less invissible. I have found the possibility to do almost the same thing in paint.net, but the nice thing in pictureIT was that it made it more and more invisible from the edge to the center. It was very nice when you wish to put a pictur (small) on another (big) and keep focus on the center and at the same time noe get a sharp edge. My question is, how does I do this in paint? Is it any plugin that can help me whit it ? Petter Quote
petters Posted September 9, 2009 Posted September 9, 2009 Hi, in Microsoft Pictur IT it was functionality to make a picture more or less invissible. I have found the possibility to do almost the same thing in paint.net, but the nice thing in pictureIT was that it made it more and more invisible from the edge to the center. It was very nice when you wish to put a pictur (small) on another (big) and keep focus on the center and at the same time noe get a sharp edge. My question is, how does I do this in paint? Is it any plugin that can help me whit it ? Petter Quote
bEPIK Posted September 9, 2009 Posted September 9, 2009 Im not sure if we're thinking about the same thing or not but have you tried using then selecting then changing :AllColorChannels: to :AlphaChannel:. Right click on one of the glowing nubs if you want to invert the transparency. Remember to use different layers Quote Water, Wood and Hair Tutorial
petters Posted September 9, 2009 Author Posted September 9, 2009 Thanks. The onley thing I wonder about is if it's possible to to this from the edge to the center, and not from the center and then to (or past) the edge. Quote
