mylady Posted August 9, 2006 Share Posted August 9, 2006 hi~ Paint.net is a great work. But i find there's no funtion to deal with the picture whose format is GIF. Sometimes,we need to get rid of some static GIF pictures such as reduce the spaces in the disk.Would you pls give me some tips about this. Thanks a lot! Quote Coding all the way... Link to comment Share on other sites More sharing options...
trickman Posted August 9, 2006 Share Posted August 9, 2006 EDIT: why do you wanna get rid of gif's? Quote Link to comment Share on other sites More sharing options...
mylady Posted August 10, 2006 Author Share Posted August 10, 2006 maybe there's some mistake in my comment. I mean to do some Operation on a GIF format picture. Quote Coding all the way... Link to comment Share on other sites More sharing options...
trickman Posted August 10, 2006 Share Posted August 10, 2006 oh. but PdN does not do animation, just to let you know. And you can open the file, and "Save As..." other file extension. Quote Link to comment Share on other sites More sharing options...
alexcohn Posted August 13, 2006 Share Posted August 13, 2006 Is there a way to save an image as 256-color BMP file? Actually, I could not find any way to save BMP other than 24-bit color. The workaround I have found is to save as GIF, open the result in Windows Paint accessory and save there as BMP. I hope that direct "save as" will be available soon. Quote Link to comment Share on other sites More sharing options...
