Helpmeplz Posted August 15, 2009 Share Posted August 15, 2009 I am trying to make a iPhone background but I cannot figure out how to make a add a photo to 480 by 320 pixels and keep it that size. Quote Link to comment Share on other sites More sharing options...
DarkShock Posted August 15, 2009 Share Posted August 15, 2009 If your current image is 480 by 320 and you add an image larger than that then Paint.NET will ask you if you want to keep it the original size or expand the canvas. In your case, keep the canvas size. :wink: Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
Helpmeplz Posted August 15, 2009 Author Share Posted August 15, 2009 If your current image is 480 by 320 and you add an image larger than that then Paint.NET will ask you if you want to keep it the original size or expand the canvas.In your case, keep the canvas size. :wink: I made a canvas 480 by 320 and I want to add a image to it but when I I open a image it makes a new canvas Quote Link to comment Share on other sites More sharing options...
DarkShock Posted August 15, 2009 Share Posted August 15, 2009 Well then copy the image you opened an paste it into your 480 by 320 image, but don't change the canvas size. Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
