AH1 Posted August 4, 2009 Share Posted August 4, 2009 Hi, I've been using PDN for about 9 months now and have really enjoyed it. I have a quick question and I was hoping someone could help me out. I would like to put on logo on a brick wall and make it look like it is painted on. I searched through the forums and found one tutorial but it only used color burn and didn't give the desired effect. I think I need to use displacement but am not sure how to use it to get the effect I am looking for. I tried looking at the flag tutorial that goes along with it but I can't traslate it into my situation. Any help is appreciated. Thanks, Alex Quote Link to comment Share on other sites More sharing options...
APShredder Posted August 4, 2009 Share Posted August 4, 2009 You may want to check out the Displacement and Alpha Mask plugin, if you haven't already. :wink: Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
AH1 Posted August 4, 2009 Author Share Posted August 4, 2009 Thanks. I had downloaded that but I'm still not sure what I'm doing even with these steps: Ash wrote:Bottom layer=Image A Top layer=Letters Run the plugin on top layer, use Image A as "mask" Adjust setting in plugin. See letters change. My bottom layer is my brick wall, top layer is the logo (background removed w/ magic wand) and then I use the wall as the mask as well. It just kind of distorts the logo and doesnt look like its on the wall. I'm trying for a look like sample 2 in the plugin thread. Not sure what I'm doing wrong. Theres a texture plugin I found that I may try but apparently I need to download something else to make it run. Quote Link to comment Share on other sites More sharing options...
Ash Posted August 4, 2009 Share Posted August 4, 2009 Post the images of what you've done so far. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
