Circles And Lines Help!
play around with shapes and layers. The ripple plugin can create a ideal circle (with others inside gradually getting smaller) for vector and in that tutorial i showed you it makes vectors halfway through (admitadly didnt go into detail)..perhaps use custom brush plugin?
