rune Posted July 23, 2009 Share Posted July 23, 2009 I am attempting:) to place text on a picture that will be used as a flyer.... It appears that I can't type all the text in 1 box, as I need different size text for different lines and it seems you can only change the size for all the text in that box.. or layer if that is the correct term. The problem seems that after I open a new box I can't go back to the rpevious layer to move it, such as centering or to change the text size... any help would be greatly appreciated... thanks Quote Link to comment Share on other sites More sharing options...
APShredder Posted July 23, 2009 Share Posted July 23, 2009 Yeah, thats one of the probelms with the current version of Paint.NET. Once you place text it can't be edited. :? Rick is going to improve text-editing for the next version, but it the mean time you could try the Re-Editable Text Plugin. Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Curmudgeon Posted July 23, 2009 Share Posted July 23, 2009 if portions of your text are on separate layers, you can move the whole layer around with the Panelling plugin, or by using for instance, go to the appropriate layer, press Ctrl-A to select the whole layer, then use to move it if you want text centered around where you start typing, use :TextCenter: at the top Quote Link to comment Share on other sites More sharing options...
rune Posted July 23, 2009 Author Share Posted July 23, 2009 THANKS YOU GUYS.. THINK I GOT IT.... ONE OTHER QUESTION.... PLEASE [PLEASE..... ANY WAY TO LIGHTEN THE BACKROUND PIC SO THE TEXT SHOWS BETTER? /...THANKS Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 23, 2009 Share Posted July 23, 2009 Enough with the shouting already! To lighten the background pic first select that layer, then go to the Adjustments menu & select the Brightness & Contrast option. Fiddle with the two sliders until you have the contrast you need for the text to stand out. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
