ziggy161 Posted July 21, 2009 Share Posted July 21, 2009 Hey everyone, first post I've been trying to create an A4 leafet for business. Now I have the right dimensions, 2480 x 3508 pixels or 8.29 x 11.69 inches with 300dpi but when I print the image, it's huuuuge! Takes up 2 pages. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
DarkShock Posted July 21, 2009 Share Posted July 21, 2009 I think I found your problem. I made an image that was 2480 X 3508 and the print size in inches was nowhere close what you said it was. It has a print size of 25.83 X 36.54 in which is more than three times the size you wanted. Here is what I got: If you want the image to be 8.29 X 11.69 you will have to use the pixel size of 796 X 1122. Hope this helped. :wink: Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 23, 2009 Share Posted July 23, 2009 The dimensions of the image divided by the resolution (pixels/inch or whatever) will give you the final dimensions. If you're having problems with printing Try Simon Brown's Printer+ plugin: viewtopic.php?f=16&t=27968 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
