minjarrah Posted July 19, 2009 Share Posted July 19, 2009 Hi, Is there a plugin to achieve an edge effect like the one in the attched image? Quote Link to comment Share on other sites More sharing options...
flip Posted July 19, 2009 Share Posted July 19, 2009 I don't think there's a plugin, but I think I have an idea how to achieve the effect. Make the top layer a border of the color you want the edge to be, then try using dents on it with a high roughness. I can't write a big tutorial on it right now, but I've done it before. Quote Gallery Link to comment Share on other sites More sharing options...
APShredder Posted July 19, 2009 Share Posted July 19, 2009 You may want to try the Fade Edge plugin (You have to download the whole plugin pack to get it though). It may not be exactly what you want, but it might be a good start. Good Luck. Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 20, 2009 Share Posted July 20, 2009 Try this tutorial: viewtopic.php?f=15&t=3831&start=0 (hint: look at the last image in the first post :wink: ). Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
