Problems installing... What?
A long time ago i had paint.net installed but then uninstalled it. Now i am trying to reinstall it and i get these errors: There is a problem with the Windows installer package. A program required for the install to complete could not be run. and also: A network error occured attempting to read from the file: C:\ProgramFiles\Paint.net\Staging\PaintDotNet_1455716441.msi. Then it says fatal error during installation. Can someone help me?
1st thing I am going to ask is, do you have the .NET Framework installed ?
2nd if the 1st one did not fix it go to your %temp% directory and look for files PdnMsiInstall.log and PdnSetupNgenInstall.log and post there contents here.
3rd give more detail about your system.
Hopefully the 1st one is the problem and you fix it.
HITMAN,
Yes, i do infact have .NET Framework installed. Can you give more detail because i don't understand what to do when you said "go to your %temp% directory and look for files PdnMsiInstall.log and PdnSetupNgenInstall.log and post there contents here."
